Any Pros and Cons with using Toluene?
Old May 8, 2003 | 07:28 AM
95 Silver TA's Avatar
Question Any Pros and Cons with using Toluene?
I wanted to see if anyone has used this product and if there is any ill effects of using it. I had 2 friends that used this product in thier cars (a blown 97Z and a Audi S4). They both claim the car picked up a lot more ballZ but I wanted to know if there was any ill long term effects from using this product.
I have read that using High Octane Leaded Fuel works great for power but does damage your cats and O2 sensors.
Does Toluene do the same? Any Experience that you would like to share?
http://www.daliracing.com/v666-5/inf...?articleID=410
Thanks for any input,
Claude
Old May 8, 2003 | 06:03 PM
LWM's Avatar
LWM
I have tried both Toluene and Xylene, and like the Xylene better. It seems to suppress the knock better than Toluene. I did not notice any difference in power levels, other than what may be attributed to the reduced knock.
I have been using a mixture of 20% Xylene and 80% Premium gasoline for the last year, no ill effects as of yet. Take note however, Xylene is a very powerfull solvent and may cause deterioration of the soft parts of the fuel system ... don't use too much and you should be ok.
Toluene is not as harsh a solvent as Xylene.
Hope that helps
LWM
Old May 8, 2003 | 06:44 PM
Thank You.....Much appreciated.
Any one else running either and what kinda timing are you running at WOT?
Old May 8, 2003 | 07:33 PM
Mikael's Avatar
Xylene is 117, toulene is 114. I'd add in a few oz's of Marvel Mystery Oil with every tank, substitue ATF if you can't find MMO
Old May 8, 2003 | 07:53 PM
What does Marvel Mystery Oil do?
And where can I learn more about it?
Did you ever try toulene? If so what kinda results did you see (good or bad)?
thanks again,
Claude
Old May 8, 2003 | 09:21 PM
Mikael's Avatar
Never used toulene, but have no complaints about xylene.
MMO can be found at just about any parts store, it lubricates the fuel system. Xylene is a paint thinner, so mmo compensates for it.
Old May 9, 2003 | 07:27 AM
Cool thank you for all the responses guys....Much appreciated!
Claude
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 9, 2015 03:33 PM
