How much timing are you guys running at WOT?
Old May 8, 2003 | 07:01 PM
95 Silver TA's Avatar
Question How much timing are you guys running at WOT?
On 92+ octane and
On 104 octane.
I am currently running 24 degrees of timing in the upper rpms and I am getting no knock with Sunoco Ultra 94, I will be bumping upto 26 and will monitor it. Please look at my setup in the sig to see what I have done. The car was street tuned and I will eventually get it on the dyno but I am really curious to see what everyone else running and how well it works for you
I do have a MSD Box which I will use to combat any potential timing issues too.
Thanks for any input,
Claude
Old May 8, 2003 | 07:24 PM
BigDaddy's Avatar
Claude, if you don't mind my asking, what size are the gauges you have installed in the ventillation ducts?
Old May 8, 2003 | 07:49 PM
Willie's Avatar
305 TPI
9.22 CR
AFR 190's
Twin IC's
Water/Alcohol injection
14-psig boost
91 octane
36 degrees
No knock
Old May 8, 2003 | 07:50 PM
They are 2 5/8 Autometer Mechanical Boost And Electric Fuel pressure gauges. I got the Idea from board Member and Friend Fred (Injuneer).
Hope that helps, If you have any more questions, please feel free to ask.
Thanks,
Claude
Old May 8, 2003 | 08:26 PM
Originally posted by Willie
305 TPI
9.22 CR
AFR 190's
Twin IC's
14-psig boost
91 octane
36 degrees
No knock
WOW
Thanks for the info dude and that is one of the nicest 3rd Gens I have seen in a long time...Glad to hear you drive it daily
Any one else care to share?
Old May 8, 2003 | 08:31 PM
BigDaddy's Avatar
thanks for the info. I had seen them in Fred's car, but I didn't know what size they were. I plan on putting a boost gauge in the same spot.
josh
Old May 8, 2003 | 08:45 PM
rskrause's Avatar
Moderator
29 degrees.
Rich Krause
Old May 8, 2003 | 09:24 PM
Originally posted by rskrause
29 degrees.
Rich Krause
Thanx for the info Rich, is that with 92+ octane or with race gas?
Thanks,
Claude
Old May 8, 2003 | 09:55 PM
rskrause's Avatar
Moderator
Thanks,
Claude
I run either 94 octane unleaded or 100 octane unleaded when I plan to use the N2O. I bought a drum of 104 octane unleaded to play with this year when at the track.
Rich Krause
Old May 9, 2003 | 07:44 AM
Rich Krause
SHCAWEET!!
Thanks again Rich,
Feffman
Oct 9, 2015 05:42 AM
jayblev95
Jan 20, 2015 01:30 PM
jayblev95
Dec 1, 2014 06:55 AM
sleeperZ96BT
Aug 16, 2002 02:24 AM
Red97LT1
Aug 7, 2002 05:45 PM
