At what boost level is O-ringing the block neccessary?
Old Apr 17, 2003 | 08:06 PM
383 LT4's Avatar
Will it be ok to run up to 15#'s of boost without O-ringing and reciever grooving the heads? What boost level are you guys running without any modification to the block? Thanks for the info.......The D1 will be a lot of fun on the 383
Old Apr 17, 2003 | 09:56 PM
Brady's Avatar
IMHO, you don't need to o-ring for 15#. I ran 15-17# with felpro gaskets and ARP bolts and never had a problem. I did start lifting the heads when we upped the boost over 20#...
good luck!
Old Apr 18, 2003 | 01:09 AM
383 LT4's Avatar
would you guys recomend head studs? That is great that you can run so much boost on a fel-pro gasket. What was your compression ratio when you ran that much boost?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
