q. on preping car for sc.
Old Apr 10, 2003 | 06:38 AM
limige's Avatar
i want to put a supercharger on my car in the future. looking to run 12-16lbs of boost or so. but i won't be able to afford it for at least a year or two.
i replaced the rear with an 8.5" 10 bolt.
i plan to fab a new torque arm, sfc, connecting arms, and panhard.
i have and eiback spring kit and plan for new shocks soon, also plan to put on some headers this winter.
as for the motor.
i have a cc. extreme energy grind 224/236 with a 114 lsa. complete kit with 1.6 pro mag rr's.
i'm planning for a new chain and most likely a vented opti swap. of course since i'm this far i want to port and polish the heads up some.
now my question.
even though i can't get the supercharger for a year or two after i complete the above, should i open the valves up to 2.02's while i have the heads off?
i'm also planning to dump a set of forged pistons in, either a -28 or -32 dish.
how will the car act till i get the supercharger? lower compression, larger cam, and opened heads? will it be fine?
what else should i consider doing?
do i need to upgrade injectors for that cam? fuel pump?
Old Apr 10, 2003 | 06:53 AM
IDOXLR8's Avatar
If you do a search you will find alot of useful info.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
