Is this OK?
Just talked to the shop doing my car they are putting in 37 lb injectors from 24. And there getting rid of the FMU said it should run better . Is that true? And does that sound like to much of a bigger injector? What does going to a bigger inj. do .Will that help me to make more HP. Or just safetly run the car...Thanks
37# is an odd number. If you are paying for them, get 42#ers.
The injectors will allow the shop to more accurately tune your car. You will likely pick up marginal HP only because FMUs make the cars so rich.
