Gapless rings for a supercharged engine?
Old Apr 13, 2003 | 09:47 PM
383 LT4's Avatar
Question Gapless rings for a supercharged engine?
What do you guys think of using a gapless ring on a supercharged engine? I have heard good and bad about them for an n/a application. Seems like they might be a good thing to none of the boost turns into blow by.
Old Apr 16, 2003 | 05:11 AM
MSM69Z28's Avatar
i have read several articles saying they definately make an increase over conventional rings. the key is where the placement of the gapless ring is. on a superchargered or NOS car, the combustion chamber can be much hotter than n/a, therefore, you should not use top ring gapless in this application, but they do make a gapless second ring. n/a cars can run a gapless top ring.
i put a gapless total seal 2nd ring set in my 69Z and it will see 15+ boost on a 383.
hope that helps.
mike
Old Apr 16, 2003 | 11:11 AM
89ProchargedROC's Avatar
from the experiences i have read about and talked to people who have actually run them the experiences have usually gone like this (whether n/a or fi mind you)
initial impressions:
great, love them, seem to work well
median results:
starting to have some issues, not sure if rings are the issue
end results:
rings became an issue, had to be changed
Some people argue most of the experiences are caused from the wrong type of honing finish on the bores and/or wrong application/installation BUT i argue if they need to have things so perfect for them to work, is that really going to be possible for a street motor?
i went with plasma moly top ring
Old Apr 19, 2003 | 12:43 PM
rskrause's Avatar
Moderator
We are talking real subtle stuff here. On the order of a few hp either way. In that light, I don't think that zero gap rings are worth the potential problems. There is potential "free" hp here, but I am not convinced they work anyway. Clearly, there is leass leakdown with a cold motor and gapless rings. But if you have "traditional" rings, properly installed, and up to operating temperature I think the difference, if any, is very small.
All this is anecdote, as I have never used them.
Rich Krause
Old Apr 19, 2003 | 01:25 PM
383 LT4's Avatar
Thanks for the replies. I guess I will just stick with the speed pro race rings. I tried gapless once before but could not really tell how good they worked since I had 2 broken oil controle rings.
Old Apr 19, 2003 | 09:04 PM
RCF925's Avatar
I'm building a blown 383 now and am using C/A Zero gap rings, But as the others have said I'm only using the gapless on the second ring and a dura moly top ring because of the heat.
RUENUF
May 25, 2016 08:10 PM
cyteone
Feb 7, 2015 06:04 PM
1963SS
Feb 6, 2015 10:05 AM
CARiD
Jan 27, 2015 06:27 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
