Miss and SES light at 4800 RPM
Old Apr 23, 2003 | 05:25 PM
apachestud's Avatar
Whenever I get into my car, if I let it rev out to 4800 RPM I get a real quick stutter and then the SES light comes on. If I keep going through the gears I'll get the same stutter at the same RPM. After a few normal start/stop cycles the SES light will go out. Any suggestions?
Thanks.
Justin
Old Apr 23, 2003 | 07:07 PM
Lonnie Pavtis's Avatar
Check your codes. You likely are setting a code for a high MAF reading. You should have purchased a MAF massager (96 & up LT1's)with your kit to prevent this error code.
Old Apr 24, 2003 | 07:57 PM
apachestud's Avatar
Lonnie,
Actually, I've aleady got the MAF massager. Is that the only thing it could be? Thanks.
Old Apr 25, 2003 | 02:32 PM
Luna's Avatar
In the past , I had it occur with the Massager.
Old Apr 26, 2003 | 01:29 PM
apachestud's Avatar
Could the massager count for the quick skip I get as well?
DetroitZ28
Feb 13, 2015 07:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
