View Full Version : LS1 Based Engine Tech
- Pics / sound of GMMG.........
- is replacing my CATS with 2 cutouts a good idea??
- Need Quick Answer On Brake Problem
- Replacement Shocks
- Orlando area CORSA /GMMG owners........
- Problems with low coolant light
- Triple guage pod for 97-01 camaros... will it work for birds?
- If you guys had my car...what would you do?
- Clutch wont disengauge!!
- I have the SLP dual-dual, will a cut-out do anything for me?
- Will it compare to an 02 trans am?
- Anyone have an LS6 head?
- Instructions on how to port TB?
- Gran MAF and Therm
- 4.10's vs. 3.73's... What's the diff?
- Harwood SS Hoods
- valvetrain mod?
- Help Installing Hurst Shifter
- What do you think my next go fast 'bolt on' should be...
- What do you think the bumpstop and EGR tube mods are worth?
- Advanced Question!
- What is an LS1 Bumpstop mod?
- BERGER exughst
- A Newbie in the house!!!
- I Need help installing ASP Crank & Alt Pullies!!!
- Transgo Question
- Turn signal trouble
- Posi-Traction Rear?
- just bought mac headers.... what else do i need?
- Quick..Will 3/8"- 16 x 3/4" Mr Gasket........
- '98 heads on a '99...What's needed?
- Camaro B4C value?
- Will the filter fit?
- Last of the Breed
- Voltage Problems...Alternator?
- Just installed K&N FIPK
- 6.0 Liter LS1...machine work to make LS6 intake work?
- stock 98 Z28 1/8 mile times?
- Got a new toy
- I have a squeeking sound from my engine
- people w/intank walbro pump--? inside
- Destroyed Camaro's....
- Strange exhaust rattle....
- More suspention questions?
- Where are the bleeder screws for the cooling system?
- Almost done with my 160 thermostat install.....but I need help
- Does this sound right?
- NEED HELP ASAP PLEASE!!!!!
- looking for a ground in 2001 T/A
- ?'s about the electric cutout.
- GMMG vs CORSA
- Anybody here use BFG G-Force Tires?
- Bought a NOS Dry Kit......
- Mecham Hoods
- Bad Lifters?!
- Price is Right?
- Poll: Supercharging/Turbo charging and LS1....Good Idea?
- Flowmaster Muffler vs. Catback
- Going to muffler shop soon, would this sound good?
- rear end swap question
- New '02 Z28!!!
- Throttle sticking...
- Poll Time: Who owns a 2002 SOM Z28?
- Help me feel better about tranny choice!
- How can I tell which part of tie rod is bad?
- how to get this hurst handle off
- oil filters
- Lou's short stick
- Lowering springs?
- can 1.7 ratio Big Block 3/8" stud rockers be used on LS1???
- Whisper Aggressor
- Difference between lock up and non lock up torque converters
- Fuel Rail Covers
- 2002 Build Numbers
- A Tire Question
- How do I do tthe TB bypass on my LS1?
- coolant flush?
- After market Throttle Body......?
- Just dynoed my stock 98 z28!!!!!
- What is the stock throttlebody size for a 2000 Z28?
- SES Light
- How much oil do you use between each change?
- First Real Car - How do you turn off Traction Control?
- HELP - squeaky suspension
- Does your LS1 do this?
- Stock w/80 series vs Corsa?
- Stock GM y-pipe vs SLP- y?
- Can't find a straight weight answer???
- Still want to know, bent axle
- Engine bay stabelizing bar thing?
- How Fast has this combo run?
- Was thinking about a 3500 stall..does this sound right?
- did you guys see this kill story
- Z06 Wheel... Where to buy?? What size???
- Whats wrong with my car? Just got back from the track.
- Anyone point me in the right direction?
- NEED HELP!!!
- Can the Camaro handle?
- WS6 Shocks same as stock TA ??
- MMS Throttle body, help ASAP, Advice :\
- Slp/ K&N gasket?............
- Stock Rear End Sizes???
- Exhaust that won't void the warranty
- Oh no......
- wheres the pcv valve located on the LS1 engine?
- LS1 Brake upgrade...
- Electrical Problem: Any Suggestions?
- CORSA vs other exhaust?
- Car Maybe in October
- What can be done?
- New Around Here - Questions =)
- SLP Air Temp. Module
- MAF questions
- How much RWHP will i have after this?
- rough idle,then idles ok? after headers
- Platinum or copper plugs?
- Best place to get replacement LS1 car fog lights?
- Synthetics-What Brands??
- Is the LS1 Durable?
- ** Powerdyne Blower vs Heads/Cam...?
- road course in western iowa
- replace 99 camaro ss gears
- can my 2000 do this grill mod??
- Zaino employee is a JERK !!
- headers installed....IDLING VERY ROUGH!! SES LIGHT!! HELP!
- torque specs for the subframe connectors
- SHIFT LIGHT???
- Any wiring gurus out there?
- which fuse controls the headlights?
- How much does the loudmouth sound like a cutout?
- high flow bellows???
- Hooker Long Tube Question??
- Service Engine Soon Light?
- Is my fuel pump going out?
- My Yank Transmission story, or How I broke A th-400 with 320rwhp
- HPS LS-1 Head package
- 99 Trans Am Vs 97 WS6
- Anyone have an pic of the SIGNATURE SERIES Hotchkis STB?
- HELP ME WITH UNDERDIVE PULLEY ASAP
- slp lid
- EASY QUESTION what gear ratio is stock in a 2000 ram air firebird
- Auto Headlights ON mod
- OMG Need Help ASAP
- Heads Up Display...
- INSTALLED NITTO 315S ON STOCK RIMS!!!
- Anyone who has fixed or changed the ignition tumbler or switch, please help!
- What else do I need with STG. II heads swap?
- 98 Corvette cam placement in f-bodies?
- Kuhmo Ecsta MX 411
- rearend is off car and gears got wet, what to do?
- MTI B1 Cam Results in My 98 LS1
- Modded F-body or Corvette
- Just picked up my brand new 02 Z28!!
- EGR tube missing...
- Max RPM for stock bottom end LS1?
- AMBIENT TEMPERATURE GAUGE?
- How much horse power does a stock 99 SS have?
- Painting New Metal/Plastic
- Exhaust for my 2002 Z
- rear end going?
- Functional Ram Air SS Hood
- Got the Low oil light on my '02 Z
- will this radar bracket work for the F bodys?
- mounting caps on the radar..how to keep them sticking
- Where can I find free mod section?
- AC
- Free RamAir mod useless on an SS?
- Spare Tire Help!
- Small question about the LS1's factory power ratings...
- What Shifter???????Pro 5.0/Hurst/or What???????
- Has anybody ever got Low Voltage code with an o2 sim?
- cam and computer
- Newbie: stroker question
- stock LS1 head flow #s..anybody got em??
- Goin to the track on Sunday, what should I expect?
- Free Air Mod
- Can I re-use stock header bolts for my MACs??
- hmmm... curious about stock cam spec
- How to make a skip-shift eliminator for 99 SS
- Ignition and Fuel issues
- Leather seats
- Warranty
- T/A revved itself to 3,000 RPM, normal?
- M6 / Clutch questions
- Anyone have a Hughes converter?
- Whats the most power a 4 gen Fbody can take?
- help have a gremlin in my camaro,ses light and 02 sensors
- help have a gremlin in my camaro need help
- Jet performance Chip
- Sticking Clutch?????Why???????
- autotap????
- What Should I Expect ?
- 3 easy cheap/free mods for LS1ers!
- Dyno #'s with Hooker LT
- Computer mods and Throttle body
- Difference between these slave cylinders?
- New clutch time
- MoTeC Questions
- HELP: Where can I buy ZR1 style 11" wide rims????
- Camaro vs. Supra From A Roll
- Weld Racing Magnum Drag 2.0 - 786 Series Wheel
- car stumbles off of idle please help
- New Cobra only running 13.2 in 1/4 mile
- Car still spits and spudders sometimes
- question about header bolts for MACs
- LS1 power ???
- SS OWNER ALERT-FACTORY DEFECT ON 2001'S
- flowmaster muffler or SLP loudmouth
- Whats the difffrence between the LS1 and the LT1?
- high flow cat
- Turn down tips
- Need 3rd folder of LS1 Edit software. Help Plz!!!
- Coefficient of drag? Numbers?
- Let's see your cam specs/HP #s!!
- I need help
- Idle at 500 rpm?
- Spark plug change ANY HINTS???
- SERVICE ENGINE SOON light came on after airlid install....
- Airbag light...HELP ME!!!!!!!!
- Quarter Mile Times???
- Questions about a 383 stroker?
- are high flow cats and y pipe worth buying?
- Need help with unknown sound
- bad noise.please help
- Trans Fluid
- **Dilemma.....Need help quick!!**
- tires?
- HP on 2002 Z28
- 3.73 for 2002 auto Z28
- motorized cut out flange?
- best bang for my buck (engine mods)
- Mid-lengths or Longtubes???
- Clunk in 98 Z28 Drivetrain
- what do you think of the mcleod clutches?
- new best,12.72 stock motor, et streets
- Should I do front struts/springs/sway bar myself?
- Just bought my dream car...
- What gears are best for a street/strip car?
- 17x9.5 and 17x11 rims on a 2002 SS
- Spacer jouncer bumpers!!1
- Raer Seats Delete KIT
- Headlight HELP!!!!!!!!!
- confused about engines
- SLP Loudmouth+Airbox?
- Brake warping
- Clicking noise in the Transmission
- 98 camaro hypertech problems
- Anybody using Autotap for a non LS1 application?
- Sealing the airbox --- mod ?
