Weld Racing Magnum Drag 2.0 - 786 Series Wheel
I've heard from people that 15" rimms will not fit over the brakes of 4th gen camaro's. This true? I am thinking of getting a pair of the wheels mentioned in the subject, for drag use only. In 15 X 12.
Will these fit without banging out the wheel well?
Depends on backspacing. The only 15" wheels that I'm aware of that fit with no grinding are the Centerline Convo Pros. I have 15X8.5 w/5" BS.
'01 Mystic Teal Z28
A4/3.23/Leather/T-Tops
Mods List Here
12.38/110.72/1.74 60'
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
'01 Mystic Teal Z28
Mods List Here
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
Looking at jegs, http://www.jegs.com/cgi-bin/ncommerc...78&prmenbr=361
Looking at the 15x10 or 15x12. What are the RS & BC numbers?
Most of us at www.ls1tech.com run either:
Weld Draglite / Pro Star; 15x10, 7.5 backspace, with major grinding and a spacer or a wee bit more grinding and no spacer, which is what I do.
Or run:
15x8, 5.5 backspace
Centerline rims are a bit different...
1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM
Or run:
15x8, 5.5 backspace
Moshbmx1
Jan 20, 2015 03:27 PM
