tires?
I have a 98 Z28 A4, FIPK&FlowMaster, when I really punch it in Drive from a stop, I mean really hit the gas hard, my Z28 will slide left till I adjust and straighten it out. I just wanted OPINIONS wether this could be my GoodYear RSA ZH 'probably' stock original tires with 32,900 miles on them or something else. I need tires regardless,,any ideas on what type of GoodYears - RSA Z or GS-C????
first off, if those are the stock tires at 33k miles, someone was extra easy on the car, so that seems unlikely. when in the market for high performance tires, i would steer clear of goodyear...they just dont make anything that hooks up really well. for a daily driver, i recommend BFG KDW, they provide much better traction than any goodyear, and are rather cheap compared to the goodyears. (about 160 per tire). if you mostly take your car out in nicer weather and store it in the winter, i recommend either the BFG KD or the nitto 555r.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
I think the best bang for your buck street tire is the Kuhmo
$159.00 for the 275/40 YR 17's
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
