can 1.7 ratio Big Block 3/8" stud rockers be used on LS1???
Old Jul 23, 2002 | 02:16 AM
2001CamaroGuy's Avatar
Smile can 1.7 ratio Big Block 3/8" stud rockers be used on LS1???
I'm just shooting a question out here for the sake of learning.
I noticed that the Crane 1.8 rockers say they go on a 3/8" stud. Looking in my Summit Catalog, I noticed that there are several 1.7 ratio full roller rockers for Big Blocks that fit a 3/8" stud. These rockers range from $180 to $250.
Would it be possible to take a set of these Big Block 1.7 ratio rockers and swap them into an LS1 (remove bolt......pull factory rocker......put aftermarket rocker on, put bolt back in......)? If it were possible, that would seem like a VERY inexpensive upgrade when doing a cam.
Later,
Chris
Old Jul 23, 2002 | 07:01 AM
PhantomTA's Avatar
Moderator
Post
Nope. not at all
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
Old Jul 23, 2002 | 09:10 AM
zzPop's Avatar
Post
SLP has rocker arm kits for the LS1, check with them.
Old Jul 23, 2002 | 10:38 AM
Btchslp's Avatar
Arrow
I'm not thinking you'll gain anything from this mod, but you want to upgrade your springs if you do a cam. Money better spent there.
99 SS, Dark Metallic Blue, M6
SLP lid, KN, TBB, SLP Y-pipe, loudmouth
ported MAFs
Old Jul 23, 2002 | 12:16 PM
Post
ok...I get the idea...won't work . Thanks for the info. I'm not even near doing a valvetrain upgrade yet. I was just sitting around last night at started thinking (see what using your head gets you ).
Thanks again
alliance12364
Mar 6, 2015 04:39 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
