bad noise.please help
Old Jul 13, 2002 | 04:47 PM
tony starr's Avatar
Question bad noise.please help
my question is: my parking brakes make a squilling noise while driving.i replaced my rear pads thinking that would fix it.but no luck.where the parking brake goes into the rear brake area,the rubber boots are torn up.could that be the problem?what do i need to do.it sounds bad.
Old Jul 14, 2002 | 04:14 PM
nikkev's Avatar
Exclamation
A stupid question,but why are you applying the parking brakes while driving?If you're not and they are still squealing then check out the adjustment on the cable.Good luck.
Kevin
PS
I don't think the little rubber boots have anything to do with the noise.
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
