Clunk in 98 Z28 Drivetrain
Old Jul 12, 2002 | 07:44 PM
KeithO's Avatar
Post Clunk in 98 Z28 Drivetrain
I bought a 98 Z28 with the 6-speed yesterday. I have driven it about 50 miles. The car is pretty good except for one thing - when backing out of the accelerator, without the clutch engaged above about 2,000rpms there is a pronounced clunk when the car transitions from the motor pulling the car to "engine braking".
It feels like there is some slop in the drivetrain somewhere.
Is there a common problem like this with these cars? A recall? A TSB? Anyone have any idea where I should start to look?
Thanks.
Old Jul 12, 2002 | 09:27 PM
gillbot's Avatar
Post
Mine clunks as well, just some slop in the rear end on mine though! Gear lash clunk from what i hear is common.
2002 Camaro Z/28 LS1 A4 (2.73's)
Sunset Orange Metallic
Fernco, SLP Airlid, K&N Filter, 17" SS 10 Spokes
1995 Ford Aspire M5
!Torque & !Power
Old Jul 13, 2002 | 05:34 AM
KeithO's Avatar
Post
Thanks. I was hoping that this was considered normal.
Now, off to autox the Z!
Old Jul 17, 2002 | 10:21 PM
ScLeCo's Avatar
Post
Yeah its common cause the GM 7.5" 10 bolt commonly sucks
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
importkiller94
Jan 17, 2015 09:03 PM
cmdeshon
Jan 4, 2015 11:15 AM
ModdedNerd
Dec 18, 2014 10:52 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
