what do you think of the mcleod clutches?
my centerforce dual friction is ok, but not enough clutch for the 5k dumps, anyone use the mcleod clutch? hows it work? any troubles?
2000 black WS6 6speed
318 RWHP 322 RWTQ stock
best et: 12.72 with the et streets. 60' 1.81
bestmph: 109.72 first time out, no mods, on the street tires
Mods: centerforce dual friction clutch, moser 12 bolt w/4.10's
BFG dragradials, PRO 5.0 shifter
whats next: put the borla on, take baffles out of WS6 hood, tb bypass, et streets
<font face="Verdana, Arial" size="2">Originally posted by phil1001:
</font>
</font>
Grand Rapids, MI
2002 WS6
http://www.sigma-epsilon.org/steve
stevedertien@attbi.com
Whisper Lid, Grotyohann Headers and Y-pipe, Corsa Exhaust, BMR SFC's, McLeod Single Disk, Spohn Torque Arm, LCA and Panhard Rod and much more to come
I personally like my SPEC stage 3, its been able to handle 425 RWHP 400 RWT, and 4,500RPM dumps with out any problems, and it was only $500.00
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
<font face="Verdana, Arial" size="2">Originally posted by BlackBowTie:
When you are talking about "DUMPS" what do you mean? I.E. 5000 Dump?
</font>
</font>
How fast can you get your foot off the clutch? Just yank your foot away and let the clutch pedal spring back up into place ... that's a dump.
Personally, dumping over 3,500 RPM will smoke the tires in my ride. I guess I need stickier tires than these Michellin POS tires that the dealer installed.
2001 TransAm WS6, M6 3.42
HPP, TBB, 160* t-stat, MTI Lid, Holley PowerShot, Flowmaster 80, Port/Polish MAF
2001 Z28
-- R.I.P. - 06/25/02
Great info, sorry it cost so much on your end, though.
1999 Z-28 M6: Gran.MAF, LS1 MoSports intake, K+N filter,Corsa exhaust, PowerSlot rotors, Hoch. strut tower bar, still working
<font face="Verdana, Arial" size="2">Originally posted by rncotton:
You might want to read THIS first.
</font>
</font>
