LS1 Brake upgrade...
Old Jul 20, 2002 | 04:05 PM
ZPLYR 19's Avatar
Post LS1 Brake upgrade...
I have heard that the factory LS1 brakes are much better than the stock LT1 brakes... 1) is this true?, i'm going to be kicking the stock brakes into the next county, so if I were to put the braking system from an LS1 on my 95 Z 2) would this be an upgrade?? and if so, where can I get brand spanking new rotors and pads the cheapest??? Thanks for the help...
Brandon.
Old Jul 20, 2002 | 06:30 PM
nikkev's Avatar
Exclamation
Yes,it is an upgrade.There is a write-up on this somewhere but I can't remember where try the appearance section and look for Brent's website.I do know that you have to change out the A-arm (I think that's what it's called) that the caliper bracket attatches to.Good luck.
Kevin
PS
The cheapest place I've found new rotors was Autozone.They have stock replacements for like $49 each.
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
Old Jul 21, 2002 | 10:51 AM
supersp0rt's Avatar
Post
its an upgrade yes, but its not a very big upgrade. its kind of like going from the LS1 cam to the LS6 cam, and upgrade, but nothing to get excited over. id look into some Baer Eradispeed's if you want to stop on a dime.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
alex5366
Jun 8, 2015 07:52 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
