Sticking Clutch?????Why???????
Old Jul 15, 2002 | 09:29 PM
SonicMunster's Avatar
Post Sticking Clutch?????Why???????
I have had a problem with my clutch for the past couple months. There is not any problem when shifting at low rpm's. But when taking off such as a racing situation and shifting at high rpm's my clutch always seems to stick and stay half-way in always in 3rd gear. Please any help or answers why this just seems to be happening in that 3rd Gear. Thanks
1999 Black Z28 Whisper Lid w/ K&N Filter, Full Custom Exhaust, Rally Sport Styling Kit
Old Jul 16, 2002 | 08:59 AM
Chad01Z28's Avatar
Post
Sounds like your slave cylinder is about to go out. Check your clutch resorvior to see if its low on fluid.
2001 NBM Camaro Z28 M6
Mods listed on webpage...
Best ET:12.797@110.52 (1.985 60'), Best MPH 12.835@111.04
Moderator at The F-body Hideout
Old Jul 16, 2002 | 08:11 PM
phil1001's Avatar
Post
i just recently found out the true problem with these clutches after talking to mcleod for 20 minutes. 1. in the line running from the mastercylinder to the slave cylinder there is a reducer that chokes the line from 1/8" to 1/16" thus your leg has enough power to push the fluid thru, but the pressure plate does not have enough pressure to push it back fast enough, causing clutches to fail early when driven hard. easy fix, drill it out. as far as it sticking to the floor, the fingers on the pressure plate could be traveling to far and are being held there due to the centrifugal force at high rpm, or like chad t 98 camaro said the slave is on its way out.
bottom line, gm did a HORRIBLE job egineering the hydraulics and clutch. not to mention the POS 10 bolt. anyway mcleod is soon coming out with a fix, master cylinder, line, slave cylinder, throwout bearing, p.plate and flywheel that will all come in one package and fix the problem (hopefully).
2000 black WS6 6speed
318 RWHP 322 RWTQ stock
best et: 12.72 with the et streets. 60' 1.81
bestmph: 109.72 first time out, no mods, on the street tires
Mods: centerforce dual friction clutch, moser 12 bolt w/4.10's
BFG dragradials, PRO 5.0 shifter
whats next: put the borla on, take baffles out of WS6 hood, tb bypass, et streets
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
SEOJustin
Sep 24, 2015 04:39 PM
Ericksd
Sep 16, 2015 07:08 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
