Need help with unknown sound
Old Jul 13, 2002 | 05:34 PM
junk151's Avatar
Post Need help with unknown sound
When I drive my car through some rough surface or small bumps on the road, there's a metal cling coming from, I think, the back of the car. Sounds like metal hitting metal. I tried to look under the car to see if I could find the source with no luck. Anybody know what it could be? It doesn't always sound, is just when I go by over some small bumps and rough surfaces. Thanks for any help.
Old Jul 14, 2002 | 12:37 AM
WipeOutXXL's Avatar
Post
probably what's happening to my car too. Your shocks are hitting the end of each other, mostly happends on the rear right side I bet? Race alot? Have a heavy stereo? I have a single 12 inch sub in the back and depends on some bumps my car hits itself pretty card and its always the rear. i think my shocks are blown......
Old Jul 14, 2002 | 02:01 AM
stik6shift98's Avatar
Post
ya mine too its annoying
do u have any bmr suspension stuff or lm exhaust?????
Ran 13.398 with shi*ty stock bald tires havn't run with the nittos yet.
AOL SN: stik6shift98
1998 Camaro Z-28
Old Jul 14, 2002 | 10:58 AM
junk151's Avatar
Post
I hear it at the rear, not sure if it's the right or left side. I don't race it a lot, and have the stock sound system. I don't have any BMR suspension stuff nor a LM. I do have a Flowmaster muffler but the noise was there before I installed it.
Old Jul 14, 2002 | 12:09 PM
z28rktec's Avatar
Post
I have the same sound but it only started after my corsa. I need to get the *** up on ramps and check, but what I think it may be is a metal heat sheild about the rear axel (right side of car). And with a 3" pipe there isn't a whole lot of clearance. I have never heard of shocks rattling?
'01 Black Z28
loaded
K&N FIPK
Corsa
BMR STB
http://members.tripod.com/z28rktec
Old Jul 14, 2002 | 12:53 PM
Ryuhei's Avatar
Arrow
I have all stock suspension and nothing in the trunk. The rear end on these cars is just noisy. However, if you have an aftermarket exhaust, I would check to see if the over-axle pipe is banging.
2002 Sunset Orange M6 Z28
MTI clear lid, Holley filter, SLP bellows
FRA, Magnaflow cat-back, BMR SFC's & STB
Pic: http://members.fbody.com/ryuhei/pics/usa_Z28.jpg
Old Jul 14, 2002 | 03:43 PM
nikkev's Avatar
Post
Have you checked your spare tire yet?Sometimes they come loose and make a "cling" sound whenever you hit a bump.Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
Old Jul 14, 2002 | 05:13 PM
junk151's Avatar
Post
Thanks for the replies guys. I guess I'll check the spare/jack to see if that could be it.
Old Jul 18, 2002 | 01:59 AM
MrBUFO's Avatar
Post
I've noticed the same noise in my 2000 SS. A tiny, "clink-clink-clink" that seems directly related to over-road motion, coming from the rear. THE THING THAT I NOTICE IS THAT IT GOES AWAY AFTER I'VE DRIVEN A FEW MILES FROM A COLD START, AND DOESN'T RE-APPEAR UNTIL STARTING OFF ON NEXT DAY'S TRIP.
Do you guys have any ideas on what might be causing this?
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
