Turn signal trouble
Old Jul 25, 2002 | 08:23 PM
T/A Punk's Avatar
Post Turn signal trouble
Well last night I noticed that my left turn signal doesn't work at all (front or rear) and noticed that the front left bulb had burned out. I found the bulb but now I'm having trouble swapping it out with the old one as there's no easy access. so here's a stupid question. Maybe it's right in front of me (usually is) but do I have to remove the nose of the car to get at the signal lamps?
Old Jul 25, 2002 | 08:42 PM
nikkev's Avatar
Exclamation
First of all,what year and what type of car?I take it you drive a TA from your username.If that's the right car then you can just raise your headlights and reach down to get to the turn signal.If you drive a Camaro then you take out 1 10mm bolt and remove the headlight.Then the turn signal is easily reachable.Good luck.
Kevin
PS
If it's a pre-'98 car then you take out a torx bolt and remove the blinker cover.
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,IAT Tricker,TB Bypass,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
Old Jul 25, 2002 | 10:00 PM
T/A Punk's Avatar
Post
Sorry, totally forgot...98 T/A and thanks very much!
Old Jul 26, 2002 | 11:00 AM
Camaro ChriSS's Avatar
Post
I'm not sure if it differs for earlier years and models, but on my 2000 camaro, the front turn signals are reached not by removing the headlights (that's the hard way), but by going under the front bumper. There, on either side of the car, is a small black plastic access panel held in place by two screws. Remove the screws and the panel opens up to give you access to the bulbs. gives you access to the area behind the front bumper/fascia.
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
