are high flow cats and y pipe worth buying?
Old Jul 13, 2002 | 06:49 PM
zo6vette's Avatar
Post are high flow cats and y pipe worth buying?
just curious if the mac y pipe and the high flow cats are worth buying for the LS1..iam thinking about buying it..i already have the slp loudmouth exhaust on my car..any comments on the mac y pipe and the high flow cats? thanks
Old Jul 13, 2002 | 08:15 PM
nikkev's Avatar
Cool
I've heard 20-25 RWHP with the MAC's and off-road pipe.They're what I plan on going with when I get some more $$$ for mods.
Kevin
Edit:I've heard that the MAC cats suck.You can have a custom Y-pipe made for around $200 with better cats though.
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
[This message has been edited by nikkev (edited July 13, 2002).]
Old Jul 14, 2002 | 10:52 AM
supersp0rt's Avatar
Post
20-25 rwhp out of a Y-pipe and high flow cats?? sounds like you could work for SLP, aka, the masters of optimism. imo, high flow cats are a waste of valuable money, so just with an off road Y,X,or H pipe. you *MAY* see 5-7rwhp at the most.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
Old Jul 14, 2002 | 11:14 AM
V6toZ28's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by supersp0rt:
</font>
Uhhh ... you want to go back and re-read the post ... They're talking about getting the Y-pipe with the headers.
Headers and Y-pipe can give you gains in the 20 range, but not with cats. You'll have to go ORP Y-pipe to see those gains. You should expect gains in the 10-15 range on a stock motor with cats.
But I do agree that a y-pipe in and of it self isn't worth it. I'd wait until your going to do headers and do the Y-pipe then.
As for the MAC cats. They don't neccesarily suck, they are about the same as stock. And for that matter all cats are a flow restriction.
Go sans cats for maximum gain and either buy headers with swapable a cats/race pipe set up or have one custom fabricated.
Good Luck
'01 Mystic Teal Z28
A4/3.23/Leather/T-Tops
Mods List Here
12.38/110.72/1.74 60'
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
[This message has been edited by V6toZ28 (edited July 14, 2002).]
Old Jul 14, 2002 | 03:51 PM
nikkev's Avatar
Post
Hey,V6toZ28,how do you like that stall you have listed?I'm looking at the Yanks for my car and their page says I should go with the ST3500 but I think that may be a bit much.How much did your 3200 help?Thanks.
Kevin
PS
Yes,I was talking about headers and a y-pipe.As far as just a y-pipe goes,I would wait.If you are just really,really wanting one then I think it's cheaper to have one made at a local muffler shop than buying one and having it shipped.Good luck.
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
Old Jul 14, 2002 | 06:09 PM
V6toZ28's Avatar
Post
nikkev ... I sent you an e-mail, rather than hijacking this guys thread.
Old Jul 17, 2002 | 10:10 PM
ScLeCo's Avatar
Post
Go with long tubes, especially if you plan on other mods like cam, ect
and ditch the cats,
my .02
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
HectorM52
Jun 23, 2016 08:42 PM
jeff94z28
Sep 11, 2002 02:01 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 04:41 PM
blue89iroc
Jul 18, 2002 03:35 PM
