Whats the most power a 4 gen Fbody can take?
I have a 98 Z28 A4 and am planning on upping the power but Im afraid im gonna bust my axle. Just last week my buddy busted his 99 z28s axle at the track with a 360 built bottom end, cam, bolt ons, and higher stall torque convertor. He broke it before we could dyno it. Does anybody know the torque limits on the 4L60E and the stock rear end are?
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
theres no definite hp that the rear will snap at. a 6-speed will almost always go sooner. as for the tranny...the same thing goes.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
Your POS 10 is gonna go if your racing regardless, power adder or no power adder. I would just start saving for a 12 bolt now...
//BLACK 99 SS//M-6//T-Top//TR 224//112LSA ca//CNC Heads//Volant Cold Air Induction//BBK 80mm throttle body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower-Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 stat//Skip Shift Eliminator//B&M Ripper Shifter, SLP LT Headers//Borla Cat Back//Dynomax Bullit//ECT...
<font face="Verdana, Arial" size="2">Originally posted by Speedy Dragon:
Alot higher then your 6spd cars. What kinda tires did he have?</font>
How do you run 12's with a broke rear end? What broke? I dont know about you but i have seen rear ends break. Most of the time cars dont move after that.
"Mustang Killer"
Black 2002 Z28 M6 T tops
SLP LID
SLP BELLOW
K&N Fillter
"Mustang Killer"
SLP LID
SLP BELLOW
K&N Fillter
ChrisFrez
03-22-2015 07:00 PM
ChrisFrez
02-22-2015 08:47 AM
