Was thinking about a 3500 stall..does this sound right?
Old Jul 21, 2002 | 05:13 PM
6speedZ28's Avatar
Post Was thinking about a 3500 stall..does this sound right?
Will be on the car in the sig, future mods will be full exhaust, intake, and 373 gears. Maybe someday off in the future heads and cam. Thanks for all your help guys.
1998 Camaro SS A4 #2,515 OF 3017
NBM w/ grey leather
T-tops, all GM options
14,000 miles
SLP options:
Chrome wheels
dual-dual exhaust
floor mats
car cover
dash plaque
key fobs
STOCK FOR NOW, BUT MODS SOON TO COME
Old Jul 21, 2002 | 05:41 PM
Mineral's Avatar
Thumbs up
Yank ST3500 would be nice.. but if it was my car, I'd get a Yank TP4400
Old Jul 21, 2002 | 08:06 PM
6speedZ28's Avatar
Post
Anybody else? Any other suggestions as to what I should get or is a 3500 stall a good choice?
NBM w/ grey leather
14,000 miles
SLP options:
Chrome wheels
dual-dual exhaust
floor mats
car cover
dash plaque
key fobs
Old Jul 21, 2002 | 08:13 PM
Drive XR7's Avatar
Post
I think 3500 is a bit too high. Your transmission will get REALLY hot with a stall that high, not to mention it'll make it a little difficult to drive in traffic.
Go with a 2800 stall.
Old Jul 21, 2002 | 08:14 PM
Shockwave's Avatar
Lounge Moderator
Post
Why not ask in our tech forums?
Old Jul 21, 2002 | 09:06 PM
supersp0rt's Avatar
Post
a 3500 is plenty streetable...plenty! i should know, i have one. as for the extra heat issue, of course it makes more heat, its a bigger converter. that problem can be solved with an easy $60 for a tranny cooler. now that PT4400 is rather impractical for the street, id stay away from that.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
Old Jul 22, 2002 | 11:02 AM
TedH's Avatar
Post
With your basically stock configuration, 3500 will put you a bit high in the powerband in my opinion. I would recommend 2800 or so based on what you are planning in the near future.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
Old Jul 22, 2002 | 09:03 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up
Drive XR7 is right on the money. I too am considering a TC change from stock, and I got to ride in the same setup car as mine but it had a 2800, 2.5 STR (Stall Torque Ratio)9" converter in it, and the difference between my stock car and his was like day and night. I'm sure the 2800 stall will put a big smile accross your face, as it did mine.
JMHO
SteveC
Old Jul 23, 2002 | 09:21 AM
Viper's Avatar
Post
2800 is ok but you will be like me, happy at first then regret not going to a ST3500. Do the 3500 and be done with it, no loss of driveability.
Viper
98 Z28 (A4) 3.42 Gears
ASCD SS Hood
SLP Subframe Connectors
Mac Headers and Off Road Pipe
ST 3500 Stall
Ported TBody
Free Ram Air Mod
FTRA Kit
LS1 Motorsports LID
K&N Filter
Hooker Cat Back
Hotchkis St. Tower Brace
BMR Rear Control Arms
Hotchkis Panhard Rod
Old Jul 23, 2002 | 02:48 PM
Camaro ChriSS's Avatar
Post
You'll like the 3500. Make sure you get a tranny cooler put in with a stall like that though due to the heat generation. I don't know if I'd put in the 3.73 gears though... it will be tough to hook up without very good tires. And if you do hook (and you race a fair bit) both the rear end and the tranny will start to suffer. If you are a big city driver (judging by your miles you're not), with a 3500 and 3.73s, fuel economy won't be that good.
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Differential cover, SLP 2600, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, G2 DSL, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
Old Jul 24, 2002 | 10:29 AM
dohcsvt's Avatar
Post
According to tech line at Vigilante, a 3500 and 3.23 gears is the best set up for a bolt on car
Old Jul 27, 2002 | 01:24 PM
texanmutt's Avatar
Post
There are poeple that are running 12.00's w/ just bolt ons and 3500 stall converters that drive them every day.
Old Jul 27, 2002 | 03:26 PM
Trevor98ramair's Avatar
Cool
Experience speaks loudest. I've tried 4 Vig converters and 5 Yank converters, so I can give ya a little insight. A 3,500 stall IS NOT too much stall for a stock-internal LS1. There are quite a few guys on www.ls1tech.com with stock-internal engines running 11's with 4,400 stalls. I'm running a Yank Pro Thruster 4400 now, and I drive my car all of the time. I had a Vig 3200 in the car before the current converter, and it actually stalls 3,700-3,800 behind an LS1. P.I. hasn't bothered to restall them for the LS1's. A 3,500 stall is a perfect street/strip converter IMO. It's not too loose to drive on the street, but it still performs well at the track. The Vig 3200 is the perfect choice if you're wanting nice performance at the strip and nice drivability on the street. I was consistently cutting 1.68-1.69 60' times with 3.23's, stock internals, FLP headers, and a few other bolt-ons...just the basic stuff. FYI, as of August 1st, Yank will no longer sell the ST3500. Mike is discontinuing the entire Super Thruster and Torque Thruster line-up. With that in mind, I would get a Vig 3200. It will work just fine with stock programming, and it will net you .5-.6 in the 1/4. It shaved off right at .6 for me in the 1/4 with ET Streets bolted up. We do sell the Precision Industries Vigilante converters at L.G. Motorsports, so feel free to give me a call at the shop if you want to discuss converters more or order one. I'll be glad to help ya out.
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
fpete1992
Dec 11, 2014 03:51 PM
jayblev95
Dec 1, 2014 06:55 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
