View Full Version : LS1 Based Engine Tech
- 99 to 98 water temp sending unit conversion?
- e-cutout question
- Where should my a/f ratio be at?
- misfires that don't set blinking SES light
- Rattling sound on acceleration
- Help for a newbie?
- Ls1 programming!
- Help!!! Car not running right after ASP pulley install
- car making ticking noise????
- LS1 Pushrod Warranty/Recall on Pushrods?
- OPINIONS: Texas Speed true-Dual Rumbler exhaust
- The Volant CAIS really has made a difference...
- Exhaust help for a Camaro lover in the UK please
- LS6 PCV conversion??
- dual/dual part numbers. help
- loud mouth
- 99 z, buying new heads, center or perimeter bolt valve covers?
- knock retard...
- Need Help!!!
- whos uses hypertech and what setting do you use?
- Weld draglites? What specs
- TNT F-1 Kit with Aftermarket TB
- What should I do first?
- 99 v8 leaks water from overflow cap?
- How much do aluminum heads weigh?
- I got one for you guys....
- Dyno #'s
- ls1 air lid
- ASP Pulley install--- charging issues now..
- Ram air hood with no ram air (pics)
- Help!
- Keep Poping Pcming Fuse. Any Ideas
- Buying Cutout- Got a few questions.
- o2 or cat... what to do?
- differences in 98-00 LS1, 01-02, and LS6 cams?
- Just got a LS1
- Ls1 Airlid-will It Fit My 02?
- LS6 block and comp
- SLP lid question
- FAST!!! need help on MTI Clear lid(2000)
- y-pipe help please
- AC Delco Rapidfire or NGK???
- Short block
- Oil change.
- Need some help with coolant light
- O2 sensor interchangability
- Dont Laugh Intake Question
- The time has come...how do I replace my EGR valve?
- Which heads? LS1, LS6, or 6.0L?
- Can someone explain the LS1 vs. LT1 fuel,system to me?
- Lowered with 2.5" true duals... --Pics--
- o2 problem please help
- stock SS RWHP
- What is the performace difference between 1997 Z28 vs. 1999 Z28
- just got 99 firehawk
- Overheating?!
- engine noise?
- Need some advice on modding LS1 motor
- Doing Ram Air Mod Right Now, Have Question
- exhaust question ?
- Loud Popping after Header Install...help
- blinking SES?
- low oil light
- Extreme Chassis? Heard of them??? Beware..
- simple mods to make a little quicker before i get my headers
- dynomax bullet muffler on a 98 t/a with longtubes?
- ls6 intake on 98 ss
- Questions about my heads/cam setup
- Which valve spring tool? (link)
- heads/cam LS1 = 290rwhp????
- Just installed Pacesetter LT's, questions
- 1998 Trans am cam question
- Gen 3 GM Hotcam
- Ultimate LS1 Heads (apparently)
- 1998 Z28 Mod list - please make suggestions
- Currently have GMMG, lookin at Texas Speed True Duals. Good idea?
- LS1 swap
- Sputtering at low RPMs
- ASP Pulley, Yay or Nay?
- Change oil light
- Stock LS1 M6 1/4 mi times
- big inch ls-1
- What should i dyno?
- LS2 vs LS6
- LS1 to LS2?
- track kill message board
- Carb intake manifold for LS1?
- mustang dyno
- Just bought a 2000 ss but...
- Lost some top end??Any ideas?
- new LS1 Owner
- Best Headers for LS1
- Starter? Ignition Switch? Clutch/Starter Switch?
- Another...Camshaft question
- 98 EGR delete
- Too low for Hooker LT's?
- 02 LS6 in 99 SS
- best heads and cam with stock exhaust for Ca.
- TSP Rumbler
- cam suggestions
- supercharge
- vibration @ 100+ mph
- What Mods Next?
- How to force A/C compressor to come on?
- Weird engine behaviour
- ls1 head vs ls6 ?
- Can a Cam setup be had for around $400?
- what exhaust for 2000 ss camaro
- Think I can break 400hp?
- 98 Z28 with 105k on the clock
- Cam Swap Hint
- X-Pipe?
- header and Y pipe question
- Bore out to 382ci
- All opinions, comments, ideas, etc welcome......
- CAI came on all SLP cars right? mine doesnt
- Stock heads with what cam and headers?
- Spring Compressor.. cam install ?
- check engine light??
- RPM's ??
- ?? on off road pipe.........
- adapter
- LS1 Swap into Mid Engine Sand Buggy Questions..
- Just pulled my codes.........
- Longtube exhaust note....
- Car shift 1st to 4th quickly after CAM install
- Did I make a mistake? LS1 nightmare
- Best Pricing???
- Bought car, have a few ?'s
- Hedman LT's and back exhaust for LS1's
- Which Maf better?
- Harlan Shift light install problems
- Zo6 conversion
- headers Q
- flowmaster SES???
- MAF screen removal
- exhuast cut-outs
- good idea/bad idea?
- 400 to wheels...
- ASP pulley question?
- What heads for my setup?
- Squeaking belt tensioner
- What Pulley To Get?
- about that pcv mod on install university...
- Cam tuning question
- Affordable rotating assemblies are just around the corner!
- 402 short blocks for under $3500.
- IDIOT dealer problems, Bank 1?! Which is which?
- Hooker Headers and Y-Pipe
- Airbox
- cam timing
- Best cam for stock LS1?
- G-tech On My 99 Ss
- pondering cam swap...input???
- cam and heads
- Engine Cuts at 120
- mods or supercharge
- installed MAC off road pipe on my 00 Ls1 and car runs like crap?
- How Loud?
- Rookie Engine Mods
- Is this 2001 SS a good deal?
- ls6 intake
- Bang - Help!
- Slight whistling at 1200rpm accel
- Which TB: Shaner S2 or LS1speed Inc>>>
- LS1 Gauges on the Fritz
- Need quick answer, argue with dealer over repair
- Shorty headers worth it..
- Question on HTPP III
- "GM Hotcam"
- Help me kill a srt-4
- Possible?
- Y pipe help
- What do ya think
- Need help...real easy
- 6.0 ?s
- Here's the mystery connector, can anyone ID it?
- wrecked 02 i am pulling engine,trans need to know top or bootom,FOR BODY SHOP REPAIRS
- hooker y-pipe on Pacestter headers?
- LS1 conversion
- Rocker arm kit installation Question?
- Help!! Intake Manifold questions
- LS1 blcok w/ TPI conversion
- Need some Idea / Help
- LS1 vs LT1
- Anyone using oil additive to quiet piston nock?
- What else for MAC install?
- LS1 Tractioin Control Question
- Nothing Like To Much Torque....
- Does magnaflow sound good / give good hp gains?
- COMP 978 SPRINGS. Machining required?
- Help ID this SLP intake mod?
- Qtec upgrade for motor? Pitman?
- kook header's
- LS6 Cam
- Loud exhaust setup
- LS6 intake vs. LSX
- Placebo or Actual SOTP Difference
- Car died on the way home :(
- Results after cam install tr230/224
- Engine Missing Rookie needs help
- SLP Underdrive pulley
- y-pipe and hooker lt's
- Holes In Lid???
- need help figuring out what gears i have???
- cost of big cube ls1
- comp cam base circle
- SLP flowpac vs SSRA
- Best exhaust to install for HP gains?
- strange noise coming from valve cover...LS1
- Service engine light question
- New dyno numbers
- Blue Smoke
- Cutouts: Do They Really Help?
- TRex Thunder Racing Cam
- Is first gear selectable in a 1998 Camaro Z28 A4 2.73 gears?
- Will bad O2's make the car run rich?
- Difference between shocks and struts
- Lowering Car Need Some Help
- True Duals Second thoughts
- LS6 Intake????
- Whining coming from the engine!
- Getting ready to pick up an '01 SS
- Need torque specs
- what would you need to beat this car?
- what is it worth?
- ls1 motors
- Ls1 Vs. Lt1
- O2 Simms
- Spark Plugs
- Header Install
- Help w/ 02 sim install
- Wanting some 15" wheels and slicks on my lowered TA, what do i get?
- Need a mechanics opinion---is my engine shot?
- couple wire harness and egr questions...
- 90k Tune-Up and Maintenance
- Smooth bellows worth it?
- What's better SLP cold air kit or K&N filter charger?
- Fast 90mm TB: Where to get 4 inch air intake tube?
- WS6 Airbox
- AP-Engineering in the September 2004 issue of Chevy High Performance!
- what type of oil do you modded guys use?
- I hit the rev limiter, did it break anything?
- Sparkplugs
- How much HP...would you guess?
- damn camaro
- 30,000 Mile check
- Need some adice on piston slap?
- Upgrading
- What are some common 1/4 mile times for a '98 Z28 A4?
