Car died on the way home :(
Old Jul 27, 2004 | 12:02 AM
LT-14me's Avatar
Well, here is my situation...on my way home from work, i noticed that my voltage guage was reading a little low, it was 8pm so it was dark out and my headlights were on *go on automatically* and as time progesses the meter continues to dip lower and lower until eventually the "check guages" light comes on...i realize now that i am running off just the battery and my dash lights continue to dim, and my directionals blink slower and slower, eventually i am just a hair above a dead battery my headlights were out, the abs light came on, the brake light came on the check guages light came on, and the SES light was on(ses light has been on for a long time cause my electric fan is dead and was throwing a code, 1 out of the 2 still worked and didnt impact the cars performance) So now i am thinking it is the alternator, which was causein me to run off the battery...i cant check the codes..cause i dont have a predator or anything Does this sound like an alt problem? If yes then what type of alt would you recomend replaceing it with? or could it be that something was causeing the battery to drain? I just barely made it into my driveway the car was sputtering and almost stalled out. I have a 98 LS1 M6 Camaro SS. All stock except for mods in sig. thanks
Old Jul 27, 2004 | 07:46 PM
LapeerZ28's Avatar
Re: Car died on the way home :(
Easy enough to diagnose. Either charge up the battery, start the car and apply a voltmeter to the battery. If less than 14 then alternator. Or just pull the alternator, take to Autozone (or your favorite auto store) and have them check it.
Good luck.
Tony
Old Jul 28, 2004 | 11:16 AM
Taspeed's Avatar
It the alternator. No question.
Old Jul 28, 2004 | 12:41 PM
Klypto's Avatar
almost 100% sure its the alt, same exact thing happened to my 98 v6.....
cory
Old Jul 28, 2004 | 04:23 PM
LT-14me's Avatar
thanks guys just got the car back today 324 dollars later my car is back on the road
bfmv13trivium
Jan 14, 2015 09:57 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
