99 v8 leaks water from overflow cap?
Old Sep 3, 2004 | 02:18 AM
97transamman's Avatar
hey as the topic states i have a 99 v8. after driving for about 10 minutes coolant will start to leak out of the cap, first slowly, then itll start rushing out if i run the car for a little while longer. i tried replacing the cap and thermo (both are correct ratings) and it still does it, could the tank be warped? what else could it be? i tried a search, but the best i could find was blown head gasket or cap or thermo (which ive done) as far a the headgasket, i doubt that, i just changed the oil and it came out clean. isnt if you get white or blue smoke out of the tail pipes it means blown gasket?
Old Sep 3, 2004 | 11:49 AM
NEWBIE T/A's Avatar
Lightbulb See this TSB.
http://web.archive.org/web/200111080...06-02-001.html
I think this might be your culprit.
Britt
Biggiebound
Apr 23, 2015 08:50 AM
Blood type Z28
Apr 8, 2015 11:34 PM
alex5366
Feb 17, 2015 10:43 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
cristian1311
Nov 23, 2014 02:22 PM
