Lost some top end??Any ideas?
Old Aug 19, 2004 | 05:28 PM
Killaz's Avatar
Well 2 months ago i was turning 12.75@108-109MPH with my 16" street tires. The only thing i changed is, i want to 16" M/T et streets and I have my 18" c-5 wheels up front. Now im turning 13.10 @ 104-105. Could the new tires and wheels have hurt me that much? Or is there something else i should look at?
Holla Adam
Old Aug 19, 2004 | 06:52 PM
Mindgame's Avatar
Re: Lost some top end??Any ideas?
So you went from a 16" tire set (radials all around) running 12.75 to 13.1 using a drag-slick 18" front setup?
I don't think you'd lose that much... plus you're now launching on a slick! What do the 60' times look like?
I'd venture it's something mechanical... maybe valvesprings. Have you performed a compresion or leakdown test?
-Mindgame
Old Aug 19, 2004 | 08:26 PM
V6toZ28's Avatar
Old Aug 20, 2004 | 08:57 AM
DanBUCF's Avatar
What size are the ET streets? Is your car an A4 or M6? Am I correct in guessing its an auto?
Those ET streets are a lot of tire to turn with stock gears, and frankly they just don't work as well. My dad has a set of 26 X 10.5 ET streets for his SS and I tried running on them on a few runs...the best I could pull off was like a 12.90 @ 108 or something like that. I remember scratching my head afterwards as well cause I couldn't figure out what the problem is. I really wouldn't go to a larger tire until you have the gears or power to really turn 'em...it just makes the car accelerate that much slower.
Maybe I'm way off on this, but I'm pretty sure thats where your problem lies...that and I'm sure the weather is a little warmer now than it was before.
Just my $0.02
-Dan
Old Aug 20, 2004 | 05:47 PM
Killaz's Avatar
Yeah i am using the same size slicks your dad had. If i had a touque converter it would help right?
Adam
Old Aug 20, 2004 | 08:05 PM
DanBUCF's Avatar
A converter will definitely help your cause...those tires really are overkill for your current set up. Either get some gears, a converter, or more power....my vote is for more power.
Old Aug 21, 2004 | 12:02 AM
V6toZ28's Avatar
Look ... you went from 16" wheels to 18" wheels up front ... Think in terms of bigger and heavier front wheels.
Old Aug 21, 2004 | 03:48 AM
AL SS590 M6's Avatar
Moderator
And you'll probably find that there was a lot of difference due to the weather conditions.
At your power level ET streets didn't slow me down at all but I had the converter in at the same time as the tires.
Gtpguy
Jan 26, 2015 04:50 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
