Possible?
Old Aug 1, 2004 | 07:34 PM
BlackZ28Camaro's Avatar
Possible?
Ok I was needing to know if it is possible to remove the oil pan from an 02 Z28 from under the car with out having to raise the engine? I can get to all the bolts but I just cant tell once I get all the bolts off if it will come out or not.
I need to pull the oil pan off because I think I may have spun a bearing so I am wanting to pull the pan to see whats going on.
Old Aug 2, 2004 | 10:52 AM
Re: Possible?
Someone must know. Please post if you do. I was going to pull the oil pan later today if its possible with raising the engine.
Old Aug 2, 2004 | 12:40 PM
teke184's Avatar
Re: Possible?
drop the whole front cross member?
i don't think it's possible
Old Aug 2, 2004 | 01:11 PM
PAGregSS's Avatar
Re: Possible?
I would think that you'd need to jack the engine up and support it somehow to get enough clearance to pull the pan out.
Old Aug 2, 2004 | 04:13 PM
BigBadLs1's Avatar
Re: Possible?
yea i've spun a bearing before and that sucks....yup engine has to come up
