Is first gear selectable in a 1998 Camaro Z28 A4 2.73 gears?
Re: Is first gear selectable in a 1998 Camaro Z28 A4 2.73 gears?
Are you asking, or telling??
Yes, 1st gear IS selectable with an LS1, A4, 2.73 gears
. I guess it was blocked on LT1/A4/2.73 cars?
Easily fixed though, AFAIK
You can easily make it shift into 1st. There's a little rubber block that stops the shifter from going all the way back, just cut it off. I did it on my last car...
Sweet, you'll love the LS1
. As far as 1/4 times, I got 13.43 @ 106 with mine (A4/2.73's), some guys run higher 13's, and some have run near 13.00.....it all depends on whether you get one of the "factory freaks", as well as what the conditions are when you run
hotrodyou1
Dec 20, 2014 10:05 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
Jul 4, 2005 05:00 PM
2000silverz28
Jul 20, 2002 06:14 AM
