Think I can break 400hp?
Old Aug 15, 2004 | 10:11 AM
Timberwolf's Avatar
Mods so far (some ordered, some already installed) are: GTP420 cam (226/226 .595/.595 112), 918 springs, hooker long tubes woth ORY, hooker aerochamber muffler, !egr, whisper lid, K&N, free mods, ftra. When I find a decent deal I'll go to an LS6 or LSX intake (my car is a 99, BTW)
I'd like to see an 11 second time slip on the motor...
I have a 3500 stall yank converter, 3.42 gears, LCAs, SFCs, ET streets, etc to help get it down the track.
So, am I realistic?
Old Aug 15, 2004 | 02:30 PM
QuickSilver02's Avatar
Re: Think I can break 400hp?
I can let you know by the end of the week. You got pretty much the same stuff I just put in. I get my car back from the dyno shop on thursday and can't wait to see the numbers
Old Aug 15, 2004 | 07:05 PM
CRZYPWR's Avatar
Man my car is automatic. I remember I went to the track with it...I had full exhaust and full intake done with LS6 manifold, no stall. I launched the car only from 1000 rpm and my car ran 12.7 on 4.10 gear. With stall Im pretty sure I could do 12.3 if not better. So now when u have the same set up pretty much and ull add 595 lift cam... Just make sure u provide nice air flow for You motor with that cam..and dyno tune it. Youll be easily in 11s.
I would bet $100 on that
Good luck
Old Aug 16, 2004 | 02:14 PM
SLPZ28's Avatar
My friend has a auto with about the same set but with true duals, and a set of heads. His dyno at 368, with a 3500 stall. the stall coverters eat alot of power from what I've heard. Mine is a 6speed with almost the same setup you have but my cam is 224/228 581/589 lift on a 112 LSA and I pulled in the heat of the day in Florida 382/361 witout heads
Old Aug 16, 2004 | 03:50 PM
Team ZR1's Avatar
Not without a custom tune of the PCM since the CAM, esp the 112 LSA has lost low end vaccum.
The PCM torque management vlaue in your PCM was set to 350 ft/lbs, as you add more performance and spike over that value the PCM is yanking out timing and with a auto trannie also unlocks T.C so you cannot add parts for performance without tuning in those mods with the PCM software.
You also need a bit larger injector such as the SVO 30's
Old Aug 16, 2004 | 06:26 PM
mullettour's Avatar
I don't think 11 sec is out of the question. In fact I would be a little disappointed if it didn't hit 11's. 400 hp on the other hand is a little optomistic for an a4, especially an a4 with a 3500 rpm stall.
Good luck with all that. When did you get an ls1 car anyway? (I haven't been very active since I got rid of my 'maro)
Old Aug 16, 2004 | 08:32 PM
Timberwolf's Avatar
Got it back in 2002 I think. it's been to the last two M events...going sloooooooow
Old Aug 16, 2004 | 08:47 PM
mullettour's Avatar
Hmmm. I just haven't seen you post in the ls1 section up until recently is why I asked. So of the parts you have listed what do you currently have installed and what does it run with those parts.
Old Aug 16, 2004 | 08:48 PM
Capn Pete's Avatar
Originally Posted by SLPZ28
My friend has a auto with about the same set but with true duals, and a set of heads. His dyno at 368, with a 3500 stall. the stall converters eat alot of power from what I've heard.
As a rule, M6's usually take about ~12% drivetrain loss, and A4's are around ~15% loss (in "near stock" form anyways).
Now let's just say 15% loss for your buddy's A4, making 368 RWHP:
368 RWHP / .85 = 433 HP (flywheel)
That # may actually be low, considering the 3500 stall converter. With an M6, 433 HP should put ~381 HP to the rear wheels (433 HP X .88 = 381 RWHP).
Regardless of what you get at the wheels, I think it's safe to say your motor will be making well over 400 HP at the crank.
BTW, I like seeing that so many of you guys run 4.10's with your automatics! I don't feel like such a freak!!
Old Aug 16, 2004 | 08:52 PM
Timberwolf's Avatar
The only things on the list not done are the cam and springs, and they're ordered. I haven't run it the way it sits currently. I ran it 100% stock last year, but the motor has been out since then. Just put it back in about a week ago.
When it was all stock, it ran 13.95 But it is a convertible with 2.73 gears, a4 (of course), etc. I expect it should run a mid to high 12 with some tuning as it sits. So a cam and springs will have to bring some potent numbers with it. But I think if I can couple it to a better intake and TB to move some air, and a good dyno tune, it might be there.
Old Aug 21, 2004 | 01:00 AM
Originally Posted by robvas
Mike
My friend Al has a 2000 or 1999 TA convertible. 2.73's, no-name 17" tires, TCI 3500 stall, SLP lid, loudmouth...He went 13.14 @ 104 or 103. 13.6 with just the lid/catback.
He now has BFG DR's, 3.42's, and long tubes, hasn't gone any faster because his tune is completely wrong. 289rwhp
I'd imagine he could run a 12.6 or so on a perfect run. He's all stock suspension as well.
Hurry up and see what your car does, he's eager to do a cam swap.
Where did your friend get his tune? I just had mine done (wrong) and they told me 290 rwhp. I told the guy you're joking right....right....?
Old Aug 21, 2004 | 02:11 AM
dist0rtion_69's Avatar
A. If your staying all motor, you won't need bigger injectors like stated above unless you plan to spray a dry shot
B. You won't hit 400rwhp, but 400 flywheel will be smashed
C. It will definately run 11's on some drag radials much less et streets.. I would guestimate 11.70's-11.80s if you remove spare tire/jack and some unnecessary weight. I also don't think a bigger convertor would hurt
Good Luck,
Josh
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
