LS2 vs LS6
Old Aug 21, 2004 | 01:40 PM
warwickbass's Avatar
LS2 vs LS6
What's the superior engine?
Old Aug 21, 2004 | 01:52 PM
V6toZ28's Avatar
Re: LS2 vs LS6
Same engine .. the LS6 is really just a mild H/C LS1 ... M
Old Aug 21, 2004 | 01:55 PM
Re: LS2 vs LS6
I didn't say anything about the LS1.
Old Aug 21, 2004 | 02:46 PM
Beast96Z's Avatar
Re: LS2 vs LS6
The LS2 will have more cubic inches and a better intake system utilizing the 90mm throttle body, along with LS-6 production heads. Stock for stock, the LS2 will be superior, but once one adds things like the 90mm FAST intake, more cubes, and other minor mods to the LS-6, I don't think the LS2 will be all that superior.
Old Aug 21, 2004 | 04:07 PM
ULTIMTEORANGESS's Avatar
Re: LS2 vs LS6
it has more cubes and a higher CR.
itll most likely respond better to boltons and internals modifications.
they both dyno similarly.
Old Aug 21, 2004 | 06:21 PM
Re: LS2 vs LS6
Well, of course, I know it's 366 cubes to 346. I was wondering mainly about internals though.
Old Aug 22, 2004 | 07:07 PM
camaronewbiess's Avatar
Re: LS2 vs LS6
Just because they have near the same hp rating doesn't mean they dyno the same. The dyno curves mean a lot more than peak hp.
Old Aug 22, 2004 | 07:17 PM
YenkoBigBlock's Avatar
Re: LS2 vs LS6
Very true man, well said...
~Paul~
Re: LS2 vs LS6
the graphs ive seen of both they make similar power.
their curves are most likely similar too.
Old Aug 22, 2004 | 08:34 PM
toneloc12345's Avatar
Re: LS2 vs LS6
I was thinking that their dyno graphs were very close too.
TONY
Old Aug 25, 2004 | 04:55 PM
LSs1Power's Avatar
Re: LS2 vs LS6
There is a graph that compare the LS6 to LS2. The LS2 showed better area under the curve until 6K RPM where the LS6 pull 5 more HP. I would take the LS2 motor over a LS6 any day.
Old Aug 27, 2004 | 04:43 PM
BirchMan98z's Avatar
Re: LS2 vs LS6
lol I can't wait to see what new problems pop up with this 1st gen LS-2 engine.
Old Aug 27, 2004 | 04:48 PM
Re: LS2 vs LS6
Bad optispark, piston slapping, wonder what's next...
Old Aug 27, 2004 | 05:05 PM
Re: LS2 vs LS6
I know the '01 ls-6 engine had quite a few problems with bad rings, and a few bearing issues... LOL
Old Aug 27, 2004 | 05:12 PM
GreenDemon's Avatar
Re: LS2 vs LS6
From what I have heard, the LS2 has more on the low end than the LS6, and even though peak hp is basically the same, the C6 should be able to post better times than the C5 Z06. More cubes and more playing around with the valvetrain and heads is what did it, I guess.
I'll wait to sell my soul for the C6 Z06, though.
