MAF screen removal
Old Aug 9, 2004 | 10:39 AM
SpeedDemon02SS's Avatar
MAF screen removal
Hey, i have the larger flow MAF from SLP. It has a removalbe screen. Is it ok to remove that screen? Will it cause harm to the engine? Is it even worth the time of takeing the MAF out?
Old Aug 9, 2004 | 05:20 PM
Greed4Speed's Avatar
Re: MAF screen removal
Not worth it.
FYI, I've been told by several engine builders that the stock MAF flows plenty for a 450+ hp engine.
Old Aug 10, 2004 | 09:39 AM
I got it not just for the flow but the SLP larger MAF also advances your timing, i actually am getting about .1 better at the track too...and i got it for a good price on ebay.
Old Aug 10, 2004 | 12:15 PM
00pewtws6's Avatar
i removed my screen and had it bored out bigger and polished...i used the stock one.....i notice the difference when it pulls near the top of second
Old Aug 10, 2004 | 03:14 PM
CraigS's Avatar
I have an SLP MAF. Everyone I spoke with said to leave the screen in. You are already getting the advantage of the bigger bore and the screen actualy helps to straighten your air flow out.
Mangler
Old Aug 10, 2004 | 06:02 PM
I ran a ported/descreened stock MAF and had very lean conditions that caused detonation aroud 4500 RPM.
Old Aug 11, 2004 | 09:12 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile Re: MAF screen removal
I installed ported MAF ends on my 01 Z28 A4, and then had the vehicle dyno tuned 1 week later, due to a TC change.
I was running very lean on the dyno, however the tuner was able to correct the condition.
UNLESS YOU ARE PLANNING TO HAVE THE VEHICLE DYNO TUNED, LEAVE THE MAF ALONE.
SteveC
CLEAN
25
Aug 20, 2018 01:31 PM
slocody
Feb 10, 2003 01:04 PM
RedLineRev
Jan 23, 2003 03:51 PM
Teal94V-6
Aug 31, 2002 09:21 PM
sfGi8nt
Aug 1, 2002 05:54 AM
