What Pulley To Get?
Old Aug 8, 2004 | 01:53 PM
99TransAmWS6's Avatar
What Pulley To Get?
What pulley should i get for my 99 and where should i purchase it from?
Old Aug 8, 2004 | 04:09 PM
Re: What Pulley To Get?
do i go with just the 25% underdrive pully..or do i have to go with the alternator pulley to? I would rather not do the alternator pulley if it wont make a difference. Also do i need new belts?
Old Aug 8, 2004 | 07:32 PM
well im not running a system or anything..but when i did an alternator pully on my 95..it seemed to strain my voltage system..thats why im curious if i need the pulley or not.
Old Aug 8, 2004 | 09:36 PM
unvc92camarors's Avatar
i believe that if you want the same voltage, keep your stock pulley
if you are ready to risk it being low on voltage, then go for the aftermarket one
Old Aug 9, 2004 | 02:45 AM
AL SS590 M6's Avatar
Moderator
With the 6 speed car the idle is higher and the alt pulley is generally not used unless, like others have said, you have big power needs.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
