LS6 Intake????
Old Jul 23, 2004 | 11:20 PM
Articblast's Avatar
LS6 Intake????
What would I need to do to add a LS6 intake to my '99 LS1?
P.S. What the &#@$ is a DSM???? It's a car but no idea what kind!
Old Jul 23, 2004 | 11:51 PM
Grifter's Avatar
Re: LS6 Intake????
DSM stands for Diamond Star Motors. Usual refers to Eclipes and Talons.
As for the intake I cant really remember what's needed for the install. I didnt think there was much to it. Sorry, it's late and I need to get some sleep.
Old Jul 24, 2004 | 03:33 AM
stone4779's Avatar
Re: LS6 Intake????
Youll need the 2001+ front coolant tube and two rear coolant plugs
Click Here to go to an article that explains exactly how to do it.
It has the part #'s for the stuff you'll need, and plenty of pictures.
Good luck
-Chris
Old Jul 24, 2004 | 07:08 PM
teke184's Avatar
Re: LS6 Intake????
you can get all the parts brand new from www.paceparts.com
look along the left side of the page for the ls1/ls6 section and go to induction.
Old Jul 24, 2004 | 09:42 PM
mrr23's Avatar
Re: LS6 Intake????
you'll need to block off the EGR passage at the exhaust manifold also. then, you'll need to have the EGR turned off in the PCM so not to throw a code.
Old Jul 26, 2004 | 01:53 AM
Articblast's Avatar
Re: LS6 Intake????
Thanks guys!
Old Jul 27, 2004 | 02:30 PM
Team ZR1's Avatar
Re: LS6 Intake????
I would not remove the coolent lines since they allow any trapped air in a LS1 to purge out and prevent hotspotting.
You can leave the lines and just use like a Dremal and grind off the little excess plastic edges on bottom side down and intake then will fit with the coolent lines still function.
Good luck
-Chris
Old Jul 28, 2004 | 04:06 AM
AL SS590 M6's Avatar
Moderator
Re: LS6 Intake????
What your saying then is that all of the 00 and up vettes and all of the 01 and up f-bodys have hotspotting?????????????????????????????????
That when GM changed to the LS6 intake they screwed up all of the motors???????????????????????????
I think that GM found out that crossing over the coolant in the front and the back was not necessary. They still crossover in the front.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
