SLP lid question
SLP lid question
I just put on an SLP lid and I was wondering why they have a hole on the driver's side of the lid. It came with a little cap I guess to plug it off, but what's the point of it? I tried forcing it on and it doesnt seem to want to go in without bending the edges.
Other than that it did seem to help throttle response and a smidge in power though and it looks good in there.
Jason
Jason
Re: SLP lid question
1. SLP sent you/you ordered the wrong year lid. The '00+ cars have that little hole on the side for their air hose, which the '98s and '99s don't have.
2. You're talking about the hole where the rubber grommet for the IAT sensor is supposed to go. If you leave that unplugged with the IAT hanging loose, your SES light may come on.
I hope this helped.
I hope this helped.
You have a 99 which doesn't use the air pump hose, that's why the lid came with a plug. You should install the plug or you could suck something unwanted (debri/water) into the air filter.
Ah that makes sense about the air pump hose. I guess I'll try to force the plug in there one more time then. Hopefully it'll go in.
BTW, when I had the MAF sensor off it had a little debris stuck on it, like grass, a small dead bug, etc. I was gonna descreen it while swapping the lid, but decided not to because of that debris maybe breaking one of those wires or getting into the engine. Anyone else have this? I don't live in a swamp or drive on any abnormally dirty roads.
Jason
Jason
I was careful not to touch those wires. I bought the car with a K@N in it, and recharged it soon after I bought it. I don't see how small bugs could get past any decent air filter though even if the K@N's don't quite filter as many things.
Jason
Jason
k&n filters are well known for not sealing very well around the inside of the lid. something about they were not designed specifically for these cars...they just were close enough
mine came with a small foam "gasket" if you will to help seal it. check and make sure you have that. if not you could have some space around the filter where debris gets in.
oh about that rubber hose what is that for? i noticed when i bought my ss it had one too? i tried following that hose and got lost with it where does it go? or hook up to and i noticed i had all kinds of little debree on the screen of my mafs too, i thought thats what the air filter was for? i hear people talking about desceening there mafs,man id be scared to,way to much debree can get in my engine!
I think he's talking about the IAT sensor... and it really is a pain in the *** to try to get that thing to fit without breaking everything and cursing so loud your neighbors can hear...
If you haven't installed your lid yet do this.
Install the rubber grommet in the SLP lid before you even put the IAT sensor through the grommet for the new lid. The IAT sensor is delicate and can't be broken. It's protected by a little rubber cage. In case something should bump it, that will break before the IAT does.
I suggested this because the rubber gromment is tough to get in the new lid (at least mine was), and if you try to shoehorn it in there with the IAT sensor already in the grommet, you may risk breaking it.
Originally Posted by DARK AGE 53
I was afraid you had a K&N air filter, even with the foam gasket ( you do have one don't you? ) they suck. Rid yourself of the K&N and get a Holley PowerShot air filter instead.
Jason
I called SLP and no body knew anything about it. But I am staring at the damn stock lid neck that is not perfectly round so It can fit onto the notch. I cant believe they didnt modify the lid for that...
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
