Help w/ 02 sim install
Old Jul 21, 2004 | 11:55 PM
birdmanz28's Avatar
I have an offroad y-pipe installed and I am trying to turn off the engine light caused by this.. When installing the O2 sims do they replace the front or back O2 sensors.
Old Jul 22, 2004 | 01:24 AM
94ZRiCeKiLr's Avatar
Re: Help w/ 02 sim install
the o2 sims replace the REAR o2 sensors. be sure to reconnect the front o2 sensors to their plugs (you MAY need extensions) or the car will not run right.
also, my y-pipe had holes tapped for the rear o2s anyway ( i can't imagine why) so if yours does to, you may want to just screw the rear sensors into the ports and cut the wires off just to seal the holes.
Old Jul 22, 2004 | 04:12 AM
AL SS590 M6's Avatar
Moderator
Or you could go to your local autoparts and buy some plugs designed for the job and not have the sensor sticking into the exhaust stream.
Old Jul 22, 2004 | 06:56 AM
CPFarhood's Avatar
If you were maybe trying to pass a visual inspection Leaving the o2's in the y-pipe might not be such a bad idea.
Old Jul 23, 2004 | 01:10 AM
he's right the plugs make more sense...i just stuck the sensors back in because they were there...plus i didn't know they made plugs for that...
Old Jul 23, 2004 | 03:30 AM
Moderator
Not too good for a visual inspection.
Old Jul 23, 2004 | 11:02 AM
rncotton's Avatar
There's actually a GM part number for an "02 delete plug". I don't have it with me though.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
timmat1
Jun 29, 2003 09:29 AM
