I hit the rev limiter, did it break anything?
Old Jul 20, 2004 | 12:14 AM
AronZ28's Avatar
Unhappy I hit the rev limiter, did it break anything?
Okay I was messing around, shifting my A4 myself for the first time. I made the rookie mistake of bouncing off the rev limiter. The motor hit the rev limiter 3 times when I shifted from 2nd to 3rd. I'm not sure how high the engine revved, because my tach is off(car shifts itself at 5700RPM's according to the tach).
Now I am worried that I broke something, but the car seemed fine while driving normally back to my house. I didn't open her up again after being so cruel to her
Old Jul 20, 2004 | 12:18 AM
2001 B4C's Avatar
Re: I hit the rev limiter, did it break anything?
dude its a rev limiter. its there to (surprize) limit your revs . its there so that you dont damage your motor. its not the best for your motor but you didnt hurt it. your fine, just relax
Old Jul 20, 2004 | 03:27 AM
AL SS590 M6's Avatar
Moderator
And there is absolutely no advantage to manually shifting an A4 car.
You wanna shift get a stick car.
Old Jul 20, 2004 | 04:50 AM
Capn Pete's Avatar
That's not always true. Last time I went to the track, I did 6 runs. 3 of them were 13.2's, 3 were 13.3's. Guess which ones I manually shifted?
I've also bounced off the rev limiter a couple times as well, but the stock LS1's are ok 'til around ~6500 - 7000, and that's where the springs may start losing their effectiveness and let a valve float, or a pushrod could bend, so keep it below 6500 and you'll be ok (the rev limiter simply cuts the fuel, so nothing bad happens by hitting it).
Old Jul 20, 2004 | 09:16 PM
Strahley's Avatar
[QUOTE=Capn Pete]That's not always true. Last time I went to the track, I did 6 runs. 3 of them were 13.2's, 3 were 13.3's. Guess which ones I manually shifted?[QUOTE]
Manually shifting an automatic is about as stupid as watching The Fast & The Furious. There is no advantage to manually shifting an automatic. I know plenty of guys in the 10s and 11s with automatic LS1 street cars. Not a single one of them has ever manually shifted their autos
The worst you could have done was many bent a pushrod, but you would hear that. I'm sure you're fine, but stop with that manually shifting. It's AUTOMATIC for a reason
Old Jul 20, 2004 | 09:43 PM
Capn Pete's Avatar
Here are my time-slips from last month. I'm not making stuff up. I manually shifted all the 13.2xx runs. I realize that if an automatic is setup to shift at exactly the right time, then there's no point shifting manually, but in my case (and most) the tranny always shifts too soon, so holding out each gear longer was worth a full tenth of a second for me.
--- Time ----- Speed --- 60' time (quickest/fastest are in bold)
1) 13.331 @ 105.32, 2.004
2) 13.210 @ 106.09, 1.979
3) 13.269 @ 105.83, 1.954
4) 13.278 @ 105.69, 1.992
5) 13.312 @ 105.80, 1.984
6) 13.327 @ 105.82, 1.982
Old Jul 21, 2004 | 02:43 AM
Moderator
Pete,
Your right in that the only reason your manual shift runs are better is that your shift points aren't right after the gear change. So make them right. And then there will be absolutely NO advantage in manually shifting an automatic as I said before.
Old Jul 21, 2004 | 06:47 PM
94ZRiCeKiLr's Avatar
uh oh, we had this conversation a few months ago.....i also had dropped a tenth shifting my STOCK, untuned, stock converter automatic myself.
there is a performance gain in doing it when the car is stock. with an aftermarket converter and a tune of the shift points however it becomes useless...
as far as the rev limiter thing, dont worry. i know it's a little bit of a scary sound/feeling when you bounce the lmiter but its not going to hurt anything. all you did was cut the fuel to bring the revs back down to where they shouhld be. now if you were on nitrous and banged the limiter you could have had a serious problem....
Old Jul 21, 2004 | 07:03 PM
Knowklew's Avatar
I am surprised to see that with 4.10s you are still only running 13.2s. This makes me think that if i got 3.73s or a converter i would easily be in the 12s
Old Jul 21, 2004 | 09:24 PM
Capn Pete's Avatar
If you're running 13.1, I'm sure that even just gears would get you into the 12's, but a converter definitely would! I'm starting to consider that as my next step, but I'm still not sure yet (I've got a set of drag radials on order.....I'll see if they help first). Maybe the reason my times aren't all that fast are because I didn't do anything to my car to reduce weight --- I mean the spare tire & jack were still in place, my 10" sub & amp are still in the back, and I was running on street tires fully inflated around ~32 psi --- basically, complete "street trim" .
Old Jul 22, 2004 | 02:56 AM
Schantin's Avatar
This will definetly make you feel better. 6 months ago I raced some jerkoff in a Maxima. Went from 2nd to 3rd on my M6.....car went into 1st instead (this was me, not the trans...painful either way ) Anyhow, the engine went to 6500-7000 for a good 4-5 seconds, the rear chirped several times. The engine was screaming off the rev limiter, my wife was screaming from the passenger seat that I was a dumbass, my mind was screamng I was even more of a dumbass, and the dog was howling from the backseat due to all the screaming.....etc, etc. Yep, the car was only 2 weeks old and it was an extremely traumatic experience for all (dog included) .
Long story short. I pulled the valve cover on the passenger side of the engine. I pulled out EVERY pushrod. None were bent. The car runs fine 6 months later. I get the usual piston slap and valve clatter...but no damage.
If I didn't jack up my M6 after thuis stunt (and I realize I was lucky), you should be fine bouncing off the limiter at 5700RPM Count your blessings and don't do it again!!
Schantin
2002 Camaro Z28 M6
Old Jul 22, 2004 | 03:30 AM
Moderator
Originally Posted by Schantin
you should be fine bouncing off the limiter at 5700RPM Schantin
Just a small clarification. Rev limiter is at 6150-6200 on a stock LS1.
Old Jul 22, 2004 | 03:44 AM
Schantin's Avatar
You're right.......I was going off the origonal post.
Schantin
2002 Camaro Z28 M6
Old Jul 22, 2004 | 06:53 PM
CrippleFightin's Avatar
My friend miss shifted my car from 3rd to 2nd at 110 and it did TONS of damage. But what you are talking about shouldnt even concern you in the least.
Old Jul 22, 2004 | 09:43 PM
AronZ28's Avatar
thanks guys, I can sleep better at night now
