Gen 3 GM Hotcam
Re: Gen 3 GM Hotcam
The cam is alot more bark then bite. With the hot cam- your going to have to do tuning with to help with drivability. You can get a much bigger cam that will make more power and be the same on drivability. I would say to look around a tad bit more first. If cheap is your route, go for a ls6 cam, which can be had with springs and stuff new for a little less then the hot cam kit. It will make similair power to the hot cam, but drive a lot better and not **require tuning (although its best to tune after a cam anyway)
