Help!!! Car not running right after ASP pulley install
Old Sep 5, 2004 | 07:05 PM
k30's Avatar
k30
Just finished my pulley install on the TA and it runs perfect until about 2500 rpm. Then it begins to miss like it is running on 7 cylinders. It will continue to run this way at any rpm until I shut the car off. When I start it back up it runs fine until I hit 2500. It doesnt matter if I am moving or just reving the car in nuetral. Of course I got a SES light which I checked with the predator but it only told me of random/multiple misfires which I am already aware of. Visually the pulley does not seem to be wabbling and I don't notice any strange vibrations, but then agian I can't seem to go above 2500 to find out. I torqued it down to specs and followed the directions to a t.Any ideas?I would hate to have to pull it back off since it is such a bitch to get off. Is this even a pulley issue or possibly a tuning issue. The car has H/C, Kooks LT's, and predator custom tuning
Old Sep 5, 2004 | 07:11 PM
teke184's Avatar
Re: Help!!! Car not running right after ASP pulley install
did you unplug anything by accident?
how bout slipping the timing chain when you tightened it?
i say swap it back out and see what happends
Old Sep 7, 2004 | 01:13 AM
AL SS590 M6's Avatar
Moderator
Check to make sure that every thing is plugged in as it should be.
There's no way to "slip" the timing chain.
Misfires are usually linked to plugs or injectors. I imagine that a lot of vibes could also set that code. Are you sure that the pulley is installed correctly?
SpeedJunkee
Jan 27, 2015 10:02 PM
Queens94z28
Dec 20, 2014 09:11 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Jon657
Jul 19, 2002 07:51 PM
