loud mouth
Old Sep 4, 2004 | 11:46 AM
blown02ss's Avatar
loud mouth
ok im new at this. If I have the slp camaro with the slp exhaust how would i go about making it a loud mouth exhaust? i want my car to be louder . Will i lose alot of hp low end ?
Old Sep 4, 2004 | 11:51 AM
unvc92camarors's Avatar
Re: loud mouth
a loudmouth is a separate exhaust that you can buy (aftermarket)
some go the cheap and efficient way and take a dynomax bullet muffler (dynomouth) or the slp resonator (loudmouth) and welding it after their cat or in place of their cat
they then take the stock muffler off and somehow weld the tips back to the i-pipe i believe
and no, hp is only gained
the thing is with opening up flow, it moves the torque higher up in the powerband (while also gaining some)
that's why you "feel" slower but are actually faster
Old Sep 4, 2004 | 03:12 PM
Greed4Speed's Avatar
Re: loud mouth
Actually, the cats have nothing to do with it. You just place a single resonator or a bullet muffler or twister or chambered stick muffler in your I-pipe AFTER your Y-pipe not in place of your cats. The closer to the Y-pipe you get it, the less rasp. After the big bend over the rear, you place a Y and run one pipe out each side of the rear w/the tips of your choice. Look at the TSP rumbler set up. That'll give you an idea.
http://www.texas-speed.com/item_deta...ProductID=1154
You will lose no HP as stated. Some people attribute a loss of low end torque to larger exhaust pipes because of lack of back pressure but that is a myth. It is the loss of velocity and uncorrected tuning issues caused by the new free flow that may show a drop in torque.
Old Sep 4, 2004 | 04:20 PM
SFB767's Avatar
Re: loud mouth
Get the TSP Rumbler. I just put mine on Thursday and it sounds SWEET. Very deep around town and very "alive" on the highway, but whenever you let off the gas around town, it will go almost quiet. It's 2/3 the price of the LoudMouth and sounds a lot better.
Old Sep 4, 2004 | 04:55 PM
Re: loud mouth
i was just suggesting he could replace the cat with a resonator, etc. (didn't have to, could put it in the i-pipe like you stated if he wants)
thanks though for pointing out how else he could do it
Old Sep 6, 2004 | 12:08 AM
SSHORTT's Avatar
Re: loud mouth
Cut-out Sounds SWEET!!!! and Its pretty quiet at Idle but sets off every ricers cheap alarm in the parking garage at work! Try one $27shipped $30 install. if you dont like it cap it and forget it.
Old Sep 6, 2004 | 11:13 PM
burnout04's Avatar
Re: loud mouth
well just my .02, loud is usually good, but quality is better. I herd a loudmouth the other day and it really sounded horrible. It sounded like a bus with no muffler. So i would advise against it, sorry if I offended anyone.........
Old Sep 7, 2004 | 12:37 AM
AL SS590 M6's Avatar
Moderator
Re: loud mouth
Go look at an LS1 exhaust. It's totally different than your 95 LT1. There's 2 cats up by the motor.
It's really not helpful to give advice on a subject that you have no knowledge of.
Old Sep 7, 2004 | 04:30 AM
BirchMan98z's Avatar
Re: loud mouth
http://www.ls1sounds.com
Old Sep 7, 2004 | 06:53 PM
Ken S's Avatar
Re: loud mouth
This is what I can imagine..
Put a "bullet muffler" on your ipipe..
put a cutout behind your axle, right before you muffler if possible..
The bullet muffler shouldn't impede flow too much at all, and IMO, sounds better than the SLP "resonator" (i did this on my loudmouth)
Uncorking the cutout would basically give you the loudmouth sound.
Then if you want it quiet, close the cutout.
or you could put the cutout right after the ypipe... may be a bit louder..
Old Sep 7, 2004 | 07:57 PM
Re: loud mouth
oh sh**
forgot which forum i was in and what car i was talking about
yea, then ideally it would be the most sensible thing to put the resonator, bullet after the cats
for some reason i was thinking single cat and just replacing it like you could do on a 93-95
sorry about that, thanks for the correction
RUENUF
Mar 13, 2016 03:37 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
Latronaxe
Jul 17, 2015 11:55 AM
KamikaZ28
May 28, 2015 12:45 AM
CamaroSSkid_16
Aug 22, 2002 10:15 AM
