need help figuring out what gears i have???
Old Jul 26, 2004 | 11:39 AM
SMAX's Avatar
i have a 2000 a4 and the codes on the drivers door are smudged and the one in the glove box is gone. in 4th gear at 75mph i am running about 1800-1900rpm. i think it is probably 2.73's??
Old Jul 26, 2004 | 11:44 AM
autoguy's Avatar
Re: need help figuring out what gears i have???
that sounds about right. cuz i have the 3.23's and at 75 i'm like 22-2300 rpms. i can't remember if there's an axle tag on these or not that say what the ratio is. hope this helps.
Old Jul 26, 2004 | 11:57 AM
ed's85irocz28's Avatar
are you guys reading those rpm in drive or overdrive?
Old Jul 26, 2004 | 12:35 PM
teke184's Avatar
are the ls1s like the lt1s in which the shifter will tell the answer?
i know if you could select 1st gear on the shifter, it had the 3.23gears, if there was no 1st listed it was only the 2.73s
not sure if that applies to the ls1
Old Jul 26, 2004 | 12:42 PM
SMAX's Avatar
that is in overdrive. and i dont the ls1 cars are the same. i think they are all able to select 1st
Old Jul 26, 2004 | 01:46 PM
2001NBMZ28's Avatar
www.f-body.org/gears/
Old Jul 26, 2004 | 02:10 PM
Articblast's Avatar
Sounds like you have 2.73's !! Put some 3.42's or 3.73's in there and wake up the sleeping beast!!
Old Jul 27, 2004 | 09:56 AM
DANOZ28's Avatar
i also have an a4 and at 70mph i'm at 1700-1800 rpm's. i have 2:73's. on your drivers door if you see a sticker with codes, the gear code is GU2 for 2:73's and GU5 for 3:23's. my advice is traction first,then gears. (lca's, panh, sfc.also drag radials). now get out there and kick some asphault!
ChrisFrez
Mar 8, 2015 01:22 PM
BPS
9
Mar 5, 2015 10:51 PM
ChrisFrez
Feb 15, 2015 07:49 AM
smokin25th
Jan 1, 2015 09:06 AM
ChrisFrez
Dec 7, 2014 06:01 PM
