Bore out to 382ci
Old Aug 13, 2004 | 08:01 PM
CRZYPWR's Avatar
Bore out to 382ci
HEllo guys.
I am making some plans for this comming up winter. Id like to do some serious internal work on my car. I will be taking all motor apart. I have my camshaft already its a 581./581. lift cam. Now the big part. Id like to bore out my block to 382ci. My question is... is it possible to do without getting a stroker kit?
I mean ive seen some set up like that ...but never had chance to talk to the guy. IT was a ALL-BORE LS1 382ci. Also my stock heads ...is it worth porting them out ? or just get some LS6 heads and port those out ?
This is my project for this winter... 382ci...cam..heads..
I will be doing all work myslef as far as taking everything a part and put it back together.. I dont want to spend to much money on all that..
Any ideas and suggestions about how to get it done the right and not VERY expensive way (if possible :P) are appreciated !
Thank You !
Old Aug 13, 2004 | 08:48 PM
teke184's Avatar
Re: Bore out to 382ci
i don't think you can do an all bore 382ci on a stock ls1 block...maybe the 6.0L truck block.
considering a .030 overbore only picks up like 5ci...it would take alot more to reach 382ci without stroking.
Old Aug 13, 2004 | 09:21 PM
Mindgame's Avatar
Yes, new sleeves and a 4.1" bore with the stock stroke yields 382ci. Very feasible.
I would stay with your LS1 heads and have the ports worked, competition valve job, etc. I don't know your goals, but for a street build the LS1 castings are plenty adequate.
-Mindgame
Old Aug 14, 2004 | 01:04 AM
CRZYPWR's Avatar
Yea it is possible ... ALL-BORE LS1 382ci. Im gonna need new rods...pistons..but I can keep my stock crankshaft. Im jsut not sure ...of exact numbers..of a bore and all that..
And about my ls1 heads...what would be the biggest size ..taht I could port them to ? instake/exhts ? any close to stage 2 heads ?
Thank You
Old Aug 16, 2004 | 02:38 AM
Mindgame's Avatar
The bore will be 4.1" for a stock stroke 382ci build.
Thank You
You don't need the "biggest size". You need a port that is sized such that it will provide the airflow the engine needs at a high velocity. That means, a head that is conservative on port volume with excellent port shape.
I know porters use "stages" to define different levels of work, but everyone defines that a different way. You should look for port work that addresses the bowl and runner as well as the venturi and seat. So, a "complete" port job with new valves and seat cutting.
-Mindgame
Old Aug 16, 2004 | 02:39 PM
PAGregSS's Avatar
Yes it is possible. We have a guy in our club that has an all bore 388. His numbers were around 480 rwhp.
Here's his website: http://www24.brinkster.com/ezerner/pictures_index.html
Old Aug 16, 2004 | 03:11 PM
SSCamaro99_3's Avatar
Yes it can be done in an all bore setup. However you may have overlooked a few items. You said you don't want to spend a lot of money. Resleeving an LS1 block and cheap do not go together. You will very likely have over $1500 in block work, another $1000-1500 in rods and pistons, $2000+ for good heads (as stock heads will waste the additional cubes), and other ancillary items. If you are a 6-speed car, you should fully expect to purchase (or purchase shortly) a clutch ($500-1500 depending on choice), and a 12-bolt or 9 inch rear end ($2100-$2500 depending on options). Even if you do all your own assemby and installation, you should be prepared to spend $9,000 to $15,000 (again price dependent on parts chosen) in order to do the project correctly.
Old Aug 16, 2004 | 03:24 PM
CRZYPWR's Avatar
Well...A good buddy of mine will bore out my block for 250 bucks..another 200 for port job on my heads. Cam i bought for 350 bucks. Pistons and rods 1200...pushrods 100..lifters 200.... spirngs etc. LAbor on all that ..free. Rear end is done already. So ...I am looking at $2500 max. Reason why I want to do it - My motor is in really good shape with 48K miles. I wanna reabuild it...have fun with it... sell it and get 427ci C5R by next summer maybe.
I know LS1s are not cheap to play with
Thank You for Your replies.
Old Aug 16, 2004 | 03:57 PM
You cannot just bore the block. It would have to be resleeved, which your buddy cannot do for $250.
Old Aug 16, 2004 | 04:02 PM
Mindgame's Avatar
This is true. Even if you get low cost labor, you're looking at over $1000 just for the sleeves.
-Mindgame
Old Aug 16, 2004 | 06:09 PM
CRZYPWR's Avatar
So this is going to be ... RESLEEVED 382 ? OR ALL BORE 382 ?
HEy Im a newb in internal work ...thats why im here asking those questions
Thank You
Old Aug 16, 2004 | 06:18 PM
mullettour's Avatar
Thank You
It would be both. All bore because all of your displacement increase would come from increasing the bore, and a resleeve because the factory sleeves are not big enough to accept a 4.1" bore so you will have to bore it out and put new sleeves in. Sleeves here are $1320 not cheap!
Understand now?
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
