RPM's ??
Old Aug 11, 2004 | 10:25 PM
YenkoBigBlock's Avatar
RPM's ??
Whenever I shift, when I put my foot on the clutch, the RPM's rise. If I don't purposely take my foot off the gas first, it seems like the RPM's rise up when I put my foot on the cluth. But here's the thing, when I have my foot on the clutch, I can actually feel the RPM's rising. Like, the vibration from the clutch. I don't know what to think, because when I take the motor out all the way, and then shift, it feels like I have to take my foot off the gas a couple seconds before I hit the clutch, otherwise the RPM's jump.
Thanks for any help
~Paul~
Old Aug 12, 2004 | 12:15 AM
LT-14me's Avatar
Re: RPM's ??
its called NORMAL it does it so when you shift the motor doesnt have to work as hard to catch up if you down shift the computer tries to anticipate
Old Aug 12, 2004 | 07:11 AM
Re: RPM's ??
Sweet, thanks for the reply. Only thing I know, is that my Jeep doesn't do it. That's why I asked.
~Paul~
Old Aug 12, 2004 | 07:35 AM
teke184's Avatar
Re: RPM's ??
also realize that i could do with the amount of clutch pedal travel taht is required.
i know that i can safely shift with the clutch depressed about 1"! so with that amount of sensetivity, you could be depressing the clutch a small amount, enough for it to start slipping, while your foot is still on the gas.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
