01 missfire
Old Jan 11, 2006 | 04:46 PM
tatued31's Avatar
01 missfire
ive got a 01 camaro 3.8,it started running rough about 2 weeks ago,loss of power and rough idle,then yesterday i was on the interstate and whenever i was accelerating it would start shuddering and the check engine light would blink off and on until i let off the gas and backed back down to about 65 or so,had the engine codes ran and it came back with 3 codes,one is for the cat.(which is brand new,its only 3 months old) one is cylinder missfire on #2, i changed plugs and wires same thing, and the last code is the MAF.well i bought a new MAF 189.00 bucks and its still doing the same thing..when i take off it just stutters until i let off the gas...any ideas?
Old Jan 17, 2006 | 08:17 PM
Chrisz24's Avatar
Re: 01 missfire
It sounds to me like a mis-fire problem. I've had that happen 2x in my '98.
It usually requires plugs & wires, next time I'm going to get something heavier and more insulated then the AC delco ones, but my car almost always will feel a little mis when it's hot out
Old Jan 24, 2006 | 07:07 PM
tatued31's Avatar
Re: 01 missfire
well i found out it was a coil pack..replaced it and all is well again
Old Jan 25, 2006 | 09:44 PM
jonnybassman123's Avatar
Re: 01 missfire
I'm a newbie under the hood, I'm having a misfire problem also. It shudders when it's idle. I replaced all the plugs and wires except #3 I believe, cause I can't get to it. What brand of coils you recommend? A part number would be awesome.
99 z28 Haas
Apr 23, 2004 07:25 PM
street demon2k3
Mar 27, 2004 08:27 AM
eds96ragtop
Mar 5, 2004 04:43 PM
MattysTA
Feb 7, 2004 12:20 PM
ledfootz28
Nov 8, 2003 07:28 PM
