throttle body
Old Mar 26, 2006 | 01:39 PM
wakebordr2006's Avatar
throttle body
i saw that there is a throttle body bypass for the LT1, is this just for the V8 or is there something for the V6? or does the V6 throttle body not have the same problem the V8's have?
Old Mar 26, 2006 | 05:47 PM
Loochy88's Avatar
Re: throttle body
if you take the throttle body off (3.8) there is a hole near the botttom that passes through the coolant. you can fill that hole or make a spacer that will block it off. be sure to plug the correct hole.
Old Mar 26, 2006 | 06:49 PM
Re: throttle body
is it worth doing? is it the same problem as the LT1's? or is this real coolant going through it and not hot air?
Old Mar 29, 2006 | 03:00 AM
jonathan_abilene's Avatar
Re: throttle body
real coolant, its to heat the intake system for freezing cold climates
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
