oh damn it!!
Old Dec 21, 2005 | 05:50 PM
tha_slim_1's Avatar
oh damn it!!
ight gotta problem here, i put a SLP cold air intake on my car but when i did it make the engine light come on and it said "MAF or VAF low input" so i looked around the found that my MAF sensor was busted but then when i changed that the car acts like it is about to stall and its jerky at high RPMs.....any ideas on what to do.....cause i'm lost.....
Old Dec 21, 2005 | 06:01 PM
tha_slim_1's Avatar
Re: oh damn it!!
i should probably mention that i drive a 96 3.8 v6, and it stalled even before i put the new MAF sensor in it...so there u go.....
Old Dec 21, 2005 | 06:43 PM
MyShibbyZ28's Avatar
Re: oh damn it!!
If it stalled before the new MAF sensor then it is probably not the MAF sensor. Or maybe the old one and new are both bad.
Old Dec 22, 2005 | 11:29 AM
Tru2Chevy's Avatar
Re: oh damn it!!
Did you possibly over-oil the filter before you installed it? That could get the MAF dirty and cause it to throw codes....
- Justin
Old Dec 23, 2005 | 06:09 PM
PaganEgyptian's Avatar
Re: oh damn it!!
Low Input means your not getting enough flow over your MAF, is your filter dirty? Have you removed your screen? and yes, MAF sensors can be bad out of the box, especially if they are remans... All 3 of these can cause a Low voltage input code. Does it idle hooribly? how about after its at operating temprature? If it only does it when its warm, try unplugging the MAF and starting it when the engines warm, if it idles fine, then your MAF is bad. -Tim
beltrunner
12
Jul 15, 2015 08:39 PM
cmsmith
Jul 5, 2015 07:23 PM
Bloodztone
West South Central
21
Aug 12, 2002 05:22 PM
rebel-z
Nov 12, 2001 12:14 PM
