Strange brakelight prob, help!
Old Dec 29, 2005 | 10:52 AM
Snoman73's Avatar
Hey guys, my brake light has been on for a few weeks now, i checked my 3rd brake light bulbs and they fine, also the car seems to brake fine as well, the only noticable problem is that when the brake light came on, the brake pedal is now noticably spongier. I had the brakes done a year ago with new rotors, pads, lines everything, so i dont know what the problem is, any ideas?
Old Dec 31, 2005 | 09:42 PM
crasher88's Avatar
Re: Strange brakelight prob, help!
check the break fluid level if it gets too low the light will come on.
Old Jan 1, 2006 | 11:03 AM
Snoman73's Avatar
forgot to mention, i did that, even added a lil, and its still on
Old Feb 1, 2006 | 03:02 PM
Snoman73's Avatar
ttt, still having a problem, anybody?
Old Feb 1, 2006 | 07:41 PM
kallcium's Avatar
Your talking about the brake waring light on the dash right? If so it could be any number of problems, usually to do with the anti lock brakes. Could be the module or the wheel sensors or other things... they can be a little touch at times... I had it happen on my truck, It ended up being the module just above the brake pedal... it was adjusted right so I just replaced it, come to find out that GM had a recall on that part and was replaced again.... even though the auto zone part was good. Oh yeah it will also go on if you have a pressure difference between brake lines... could be a sign of the proportional valve going. Most likely its the anti lock brakes though
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
KYWes
Aug 10, 2015 07:03 PM
