Keyless entry programming
Old Feb 1, 2006 | 11:11 AM
jonnybassman123's Avatar
What do I have to do to program a keyless entry remote to work with the existing security system? My car didn't come with the remote!
Old Feb 2, 2006 | 08:03 AM
94BlackBowtie's Avatar
Re: Keyless entry programming
Are you talking about the stock keyless entry system?
Old Feb 2, 2006 | 12:59 PM
6SpdLT1Z's Avatar
shbox.com
Basically, take a paper clip, unbend it... connect the two terminals... press the lock button, take out the paper clip. (thats if your car came with power locks and you buy the right remote for it off ebay)
Old Feb 2, 2006 | 05:44 PM
Chevamaro's Avatar
Here's what the '96 owner's manual says:
-Turn the ignition switch from the RUN position to the off position. This will disarm the Vehicle and Content Theft-Deterrent/Alarm System.
-Remove the RADIO fuse. This fuse is located in the main fuse block, located on the left side of your instrument panel.
-Turn the ignition switch from the OFF to the RUN position three times quickly (within five seconds.) The vehicle will respond by locking the doors, unlocking the driver's doors and releasing the hatch. Your transmitter is now ready to match your vehicle.
-Press and hold the LOCK and UNLOCK buttons on the transmitter for 15 seconds. The vehicle will respond as in step 3.
-When you have finished matching your transmitter, replace the RADIO fuse.
Old Feb 4, 2006 | 07:12 PM
99blackSS's Avatar
This is for 98+ too (I assume 97 also). Not sure what years the paperclip way applies to.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
