urgent car problems
urgent car problems
ok well my 3.4 is having some problems it idles pretty steady buthas a miss lacks power and blows white smoke that smells like gas like a mother ****** i was wondering if someone can help me figure it out i tried everything i could think of like plugs wires coils could it be the fuel pressure regulator or something like that
Re: urgent car problems
unless you want to take it to a machenic for diagnosis or start taking the engine apart yourself, there's no way (that I know of) to know for sure what exactly the problem is. but somehow, water is getting into the combustion chamber.
normaly with a blown head gasket it does over heat but there are rare ocasions to where a blown head gasket won't cause an overheating issue. But it coudl be an intake manifold gasket gone out on you.
ok well my 3.4 is having some problems it idles pretty steady but has a miss lacks power and blows white smoke that smells like gas like a mother ****** i was wondering if someone can help me figure it out i tried everything i could think of like plugs wires coils could it be the fuel pressure regulator or something like that
You said it had a miss and smelled like gas. Are you sure its not grey smoke which would be running rich or unburned gas. When were your plug wires and plugs last changed? It could be a bad coil pack causing your miss but I dont know how to check them. Is your SES light on? Im sure someone with alot more knowlege could help more but I thought Id throw some suggestions your way...
your right it is grey i just changed the the coils and plugs the ses light comes and goes could it be a egr because it is smoking from there to and i tood it off and it looks like **** and a little rusty
http://web.camaross.com/forums/showthread.php?t=78028
i have one more question the idler pulley is mess up and its lets the belt hop around could that have anything to do with the way it is messing up because if it is slipping doesn't that mean the cam and crank sensors not goin to be able to work right??? i dunno all i can think of its starting to **** me off let me know
You may consider a can of BG40 especially if you never used it. Maybe cleaning the throttle body. Id wonder if the MAF sensor is bad and telling your car to run richer.
These are just ideas. Please verify what I am saying before you spend any more money. Plug wires and coil pack I would think would have helped regaurdless. Also if there are multiple problems get a good idea money wise of what its going to take. Dont spend more than that motor is worth. If you definately know what parts you want, get the GM part numbers. Here is a site I really like with good prices. If you find a better one let me know.
www.gmpartsdirect.com
ok well i changed the idler arm and and plugs again and it idled pretty good still alittle miss no smoke but when i drove it around the block it loaded up again fouled the plugs with gas and started to smoke could it be the fuel pressure regulator or what let me know thanks
patgoss@goss-garage.com
I was hoping someone with more knowlege and experience could diagnose it.
I would also say check the fuel pressure and go to autozone and have them check for codes. you also might want to check the coil packs. that is why I say check for codes, it should at least tell you where the misfire is and then you can work from there. I know I had a coil pack go out on my 3.8 and it did kinda the same thing no smoke but choking and backfiring.
