95 camaro...removing EGR?
Old Mar 30, 2006 | 11:23 AM
ROADRAGE's Avatar
I have all the EGR codes, so I am planning on just tearing it all out(no emissions here in MI). Has anyone done it, and if so, does it cause any problems besides throwing the code? The car has an OBD2 dataport...if that makes any difference.
Old Mar 30, 2006 | 08:13 PM
jonathan_abilene's Avatar
Re: 95 camaro...removing EGR?
you might want to tune the EGR codes out (pcmforless.com or texas speed & performance can do that).
You might want to figure out a way to block off the egr with no leaks b4 you do it.
On second thought, why dont you just get a new EGR valve? that might fix it
Old Apr 3, 2006 | 11:11 AM
natural3800's Avatar
do like I did take the egr out of the exhaust and route it to the intake. So all the valve does is suck in the intake charge instead of the exhaust. So far My engine light has stayed off.
Old Apr 4, 2006 | 04:38 PM
HBHRacing's Avatar
keeping the EGR functional would be a good idea. Less chance of detonation and lower CC temps.
Old Apr 4, 2006 | 05:01 PM
i really dont understand statements like that, I try to trust and believe them though.
I see intake air averaging around 40F-80F (depends on climate) colder than reused exhaust air (600F+++).
So how is exhaust air (600F) gonna lower CC temps and reduce detonation More so than intake air???????? I just dont get it
I know youre a real smart man HBH, I trust your good judgement..
Old Apr 4, 2006 | 06:35 PM
HBHRacing's Avatar
It's the design of the EGR valve to cool CC temps which reduces the amount of Nox emissions. EGR return gasses might be a few hundred degrees, but you have to remember that CC temps are an awful lot more then that.
Old Apr 5, 2006 | 03:08 AM
but intake is cooler than recirculated exhaust
which would be less detonation
Old Apr 5, 2006 | 10:38 AM
Yea, thats right the incoming air charge from the intake is always cooler that the exhaust charge, when the exhaust charge inters the intake it increases the air temp charge resulting in loss of horsepower. Also the main reason I did what I did, is because the exhaust charge has carbon and we all know what carbo does to a motor. So less intake temp and the less carbon in the intake equals a happy long living motor for me.
Old Apr 5, 2006 | 01:13 PM
exactly
or are we wrong HBH?
Old Apr 5, 2006 | 02:18 PM
I don't think so, I have racing experience from cars to engines and the worst thing for a car is carbon, and since the carbon only comes from the exhaust, the egr is the worst thing in history. the reason for it was to past emissions test and even now our cars pass inspection with the egr off. Mine did.
Old Apr 5, 2006 | 02:50 PM
you make me want to delete my EGR, but everyone says not to unless you have to!
PROS:
lower intake temps
no carbon
i would think better gas mileage
more HP
less chance of KR or detonation
1 lb less weight
cons:
worse emissions
Old Apr 5, 2006 | 04:51 PM
HBHRacing's Avatar
I'm not going to fight an uphill battle with people claiming that an EGR is the "worst thing in history" yet offer zero correct or even helpful information.
Your on your own.
Old Apr 6, 2006 | 02:20 AM
no I respect your opinion, i respect all the other GURU's opinions, but I just want a valid explanation
Its staying on until it dies...
Old Apr 6, 2006 | 10:40 AM
Well my explanation is simple about egrs, I have a better running engine with out it so i still am going with my opion. HBHracing you have good opions and I respect your decisions about egrs, But for guys like me who want all they can get out of their engine with basicly free modding the egr is the first thing to go.
Old Apr 6, 2006 | 02:31 PM
Maybe I should half-way block off the egr
I dont live in Alaska, I dont really need a hot intake system filled with carbon(destroying the gaskets)
