Underbody Rust
Old Jan 26, 2006 | 10:18 PM
jonnybassman123's Avatar
Underbody Rust
My drivetrain and sway bars are corroding and chipping a lot. I noticed it when I put in my flowmaster. Anyone have any recommendations? Can I fix this problem or should I just cut my loses and get another car? I post pictures tomorrow!
Old Jan 27, 2006 | 05:38 AM
TraceZ's Avatar
Re: Underbody Rust
Once a car is exposed to salt it is a death sentence. You can only postpone the inevitable. I'd recommend keeping an eye on it and selling the car right before it becomes really apparent to the "casual observer".
Old Jan 27, 2006 | 06:11 PM
2000GTP's Avatar
Re: Underbody Rust
Is it just the driveshaft, lower control, arms, torque arm, and sway bar that are rusted or is it the floorboards and everything else as well. If just the suspension and chassis parts are rusted, I wouldn't worry too much about that, but if the floorboards are rusting out then you might have some problems in the future.
Old Jan 27, 2006 | 09:22 PM
Re: Underbody Rust
It is the driveshaft, lower control, arms, torque arm, and sway bar rusting. I'll post pictures the floorboards are immaculate and so is the gas tank! How does rust killer work? Is it good or just bull****?
Old Jan 27, 2006 | 09:25 PM
TraceZ's Avatar
Re: Underbody Rust
Sorry I misunderstood you. I thought you were saying the actual chasis was rusting.
If it is just a little surface hazing on suspension components it is pretty easy to have them blasted and repaint them.
Old Jan 27, 2006 | 09:31 PM
Re: Underbody Rust
sand blasting?
Old Jan 27, 2006 | 11:05 PM
TraceZ's Avatar
Re: Underbody Rust
sand blasting?
Absolutely. Lower control arms, panhard rod, driveshaft... all those pieces can be blasted and refinished to look better than new. Or, you can replace many of those components with aftermarket pieces that are both superior in function and form.
Old Jan 28, 2006 | 12:27 AM
Intercooler's Avatar
Re: Underbody Rust
My truck has more than a little. Almost all of that stuff can be wire brushed and POR-15 coated (Paint Over Rust). That or convert it to black oxide and paint it. POR looks like powdercoating when applied right and will stop rust from coming back.
Guess they don't have picture posting here?
Old Jan 28, 2006 | 12:44 AM
silentsprintero's Avatar
Re: Underbody Rust
when i had my V6 there was a tiny tiny bit of rust on the floorboard area and i just used a wire brush to get all the loose particles free then used a rust killer (can't remember the name but looked like red donut jelly) and a black primor/spraypaint/rust protectant and it worked out great
Old Jan 28, 2006 | 06:26 AM
TraceZ's Avatar
Re: Underbody Rust
POR15 is a great product. Picture posting works.
Old Jan 28, 2006 | 09:44 AM
Re: Underbody Rust
Any performance part numbers on the diff, sway, and suspension that work well for our v6?
Old Jan 28, 2006 | 11:08 AM
nfa's Avatar
nfa
Re: Underbody Rust
Z28 sway bars are larger diameter than the v6 bars. i have a set in great condition avail for cheap
Old Jan 28, 2006 | 11:12 AM
Re: Underbody Rust
How would the larger size affect my flowmasteR??
Old Jan 28, 2006 | 11:13 AM
TraceZ's Avatar
Re: Underbody Rust
This is a good idea. I'm puting the 1LE bars on my Z28 this spring and will have the stock Z28 bars laying around as well. Maybe I should put them on my V6 car if I still have it.
Old Jan 28, 2006 | 11:15 AM
nfa's Avatar
nfa
Re: Underbody Rust
It wouldnt have any effect.
