Dash board conversion??
Old Mar 17, 2006 | 09:35 PM
LaNsY's Avatar
HeyI have a 1994 Camaro. I was wondering if it was at all possible to convert the dash board to the 97-02 style? If I bought a dash board from that year would it fit in my car? Would the screws line up and all? Would the gauges all work? This is probably a very random question but I was wondering if it was possible to do?
Old Mar 21, 2006 | 09:06 PM
yep,350L_S_1's Avatar
Re: Dash board conversion??
The dash boards shape was changed in 1998. Therefore this will definately not fit the prior year models. I also have a '94 camaro and the dash board starting cracking. It got worse and worse. My conclusion includes alot of time but the product turned out very nice. I removed the entire dash board (Got it out in 3 pieces) and fiberglassed the bottom side. After drying I flipped it over and used a filler and filled in every crack or line you could notice. I repeated this step 5 times until you could never tell if it was ever broken. Last I took a flat black and sprayed the top side and let dry. Now it is ready for installment. This takes alot of time but does not cost very much. yep,350L_S_1
Old Mar 21, 2006 | 09:43 PM
stlunatics2oo3's Avatar
yes its been done but i can't remember who it takes some rewiring. but its possible
Old Mar 24, 2006 | 08:35 AM
KHelfrich's Avatar
i have a 99 firebird dash in a 94 camare any dasy from a 4th gen will fit they are all interchangable but i usally change all the wireing too not sure how you would get the gauges in but im sure with some reasearch it could be done worst case with the newer camaro dash you may need to use an older 94-96 or 97 firebird insturment cluster
ken
Old Mar 24, 2006 | 03:33 PM
Tru2Chevy's Avatar
Shouldn't be too hard to do. I know of plenty of thrid gens running around with 4th gen dashes, so swapping 4th gen to 4th gen should be pretty easy.
- Justin
David Dempsey
Mar 12, 2016 12:42 AM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
